Timing Belt Replacement Parts (New or Reuse?)
Hi Guys! I am new to this forum and this is my first post. My 97 prelude type sh's timing belt slipped with about 135,000 miles on the clock (I know I should have gotten it done earlier). I took the cylinder head off the block to see if there was any damage and luckily there was no damage to the pistons or valves.
I am in the process of putting everything back together and would like to know what I need to replace and what I can keep. The one thing I am definately replacing are the drive belts. I bought a gasket kit (BNIB 06110-P5M-000) which includes the intake, exhaust, head and valve cover gasket. I am also replacing the head bolts since I heard they can stretch.
The next step is changing the timing belt and water pump. I would like to keep the total parts cost to a minumum so I can get the car running again and sell it. I was wondering when changing the timing belt, what parts will need to be replaced and what parts can be reused? So far I have ordered the timing belt, timing belt tensioner (auto), balance shaft belt and water pump. Do you think I can get by reusing the timing belt adjuster/pulley (18) and balance shaft tensioner (10). If I am missing any other parts please let me know. Thanks for your help in advance!
Youl'll be fine re-using the tensioner pullies. Instead of putting another auto-tensioner on, most people tend to do the H23 manual tensioner. If you do a search youll find all the info you need. You seem to have everything else in check, i would replace the oil-pump while your at it.
When you replace the timming belt you only have to worry about the auto-tensioner and the two belts. The Tensioner pullies dont need to be replaced unless their is obvious wear or damage to them. They are very well made and very durable.
jimjonez
Mar 19, 2007 05:00 PM
