New Swap Blowing white smoke
I just got my car back on the road after my swap.I have noticed that it's blowing white smoke.No specific time preety much all the time.I also noticed that There is like a water sumbstance spraing out on to my bumper.
Any Ideas, I just bought this motor and can't afford any major repairs.
Any help will be much appreciated
I don't belive so I pulled the dipstick and It looks normal.
Its a stock B16,Intake mani,Header,Straight pipe w/ muffler,Fuel press regulator.
If that helps at all
I have the same setup axcept B18C. No white smoke for me. You won't be able to tell on the dipstick. Just check next time you drain the oil. I'm stating what happened to me. I hope it isn't, especially if you just bought the motor.
youd be able to tell from the dipstick what you mean? oil would get milky and nasty. head gasket leaking wont always let oil mix with coolant. you need a head gasket most likely dude. how does the car work? idle? ive seen many times the IACV leak and cause the car to burn coolant as well.
Coolant level is good, I pulled the spark plugs today and they seem normal except for the fact that it looks like im running preety lean.
Now that you mention it I had some problem with my IACV. When I used the one from The motor I just installed it would idle at like 1800-2000 even when warm, so I swaped the one from my b17 and it idles normal.B17 also Smoked in a similar way mainly after I removed the cat.
Just as a side note I know they use marvel mystery oil in there motors when they get them to prevent a seize I quess. and I was also told to pour a little bit in each cyl. befor I start the motor to prevent cracking a piston ring and such from the motor sitting.(could it just be that burning off)
If the motor hasn't ran very much at all and with the combination of having no cat I would say this is just normal for a motor that has been sitting for some time; this is what my friends swap did.
Also noticed That It smokes more when down shifting and stopped at a red light. Not so much when I get on the throttle, but more when I let off .Also If I park the car I can watch a small amount of white smoke like float around in the exaust tip and around it.
Since you got some miles on it already it isn't just burn off so I would get a leak down and compression test just to know the condition of the motor, and as of right now it just sounds like a bad head gasket.
DRoylflush
11
Apr 10, 2011 02:11 PM
JunkyardAccord
Nov 18, 2008 10:11 AM
blue89hatch
May 7, 2008 06:29 PM
