----- NEED SOME HELP ON SPARK PLUGS
Old Nov 21, 2006 | 09:03 AM
mrinno's Avatar
Default ----- NEED SOME HELP ON SPARK PLUGS
HEY GUYS, WHAT BRAND AND MODEL DO YOU GUYS RECOMMEND FOR A 95 LS ??
Old Nov 21, 2006 | 10:23 AM
mrinno's Avatar
Default Re: ----- NEED SOME HELP ON SPARK PLUGS (mrinno)
PLEASE BUMP IF READ.
Old Nov 21, 2006 | 10:29 AM
mrinno's Avatar
Old Nov 21, 2006 | 10:40 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I don't have an LS so I can't comment, but I know there is TONS of info on spark plugs around here. Use that search link up there at the top right.
And turn off caps lock.
Old Nov 21, 2006 | 10:42 AM
dubs97integ's Avatar
Default Re: (PatrickGSR94)
I got NGK's on my 97 LS, They work great , Better than Bosch
Old Nov 21, 2006 | 10:59 AM
gsrious's Avatar
ngk bkr6e-11 should be fine for you. they are very affordable performance plugs.
if you want a hotter plug then just get ngk bkr5e-11
if you want a colder plug(which i doubt you need, unless boosted) then the ngk bkr7e-11 should do you fine.
mrinno's Avatar
Default Re: (dubs97integ)
thank you, i heard ngk was good also, thanks, sorry for caps, im at work right now, and i have to type in caps.
Old Nov 21, 2006 | 12:04 PM
Community Builder
Default Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">ngk bkr6e-11 should be fine for you. they are very affordable performance plugs.
That's what I use in my GS-R. I do NOT think those are correct for an LS. I believe LS plugs are a touch longer on the threaded portion.
Yep I was right, according to NGK's website, the copper-core plug for GS-R's is BKR6E-11, with a .052 plug gap. They copper-core plug for the B18B engine is the ZFR5F-11 with a .044 plug gap.
Old Nov 21, 2006 | 12:08 PM
mrinno's Avatar
So uh .. which one should i get for my LS ?
Old Nov 21, 2006 | 12:59 PM
Community Builder
Default Re: (mrinno)
If you want NGK coppers (good deal IMHO, just change them every 10K-15K miles) then use the ones NGK says for the LS engine.
I'm just saying, the LS plugs are NOT the same as the GS-R's plugs.
Old Nov 21, 2006 | 01:06 PM
mrinno's Avatar
OH i see, hmm .. i dont know, ill prob. just end up going to autozone or something, and ask them for some good ngk. lol
Old Nov 21, 2006 | 01:10 PM
Community Builder
I always get my NGK plugs from NAPA.
Just write down that ZFR5F-11 number and take it to NAPA and tell them you need 4, should be about $8-$9 for the set.
Old Nov 21, 2006 | 01:34 PM
mrinno's Avatar
NICE Thanks, so they are like 2-3 bucks each only ?? .. and where is NAPA ?
Old Nov 21, 2006 | 01:39 PM
mrinno's Avatar
NVM, I found on near my house, but yeah, dont i need that grease ****??
Old Nov 21, 2006 | 04:10 PM
blkacgsr's Avatar
i went with bosch platium+4's and hated them. i switched to NGK's and they work great. i'm not sure what model they are though.
Old Nov 21, 2006 | 09:45 PM
mrinno's Avatar
nice, i got them, the NGK ZFR5F-11, will install them tomorow or something, will let you guys know whats up
Old Nov 28, 2006 | 09:22 AM
mrinno's Avatar
hmm, i installed them, doesnt really make a difference, actually, everything is the same.
Old Nov 28, 2006 | 09:26 AM
iH8RICERZ's Avatar
sometimes its a night and day difference, and some times its not. Don't expect anything from replacing your sparkplugs. Its just regular maintenance like changing your oil.
Old Nov 28, 2006 | 10:10 AM
RedB20DA's Avatar
Default Re: (iH8RICERZ)
NGK Iridiums
Old Nov 28, 2006 | 11:00 AM
Community Builder
Default Re: (RedB20DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedB20DA &raquo;</TD></TR><TR><TD CLASS="quote">NGK Iridiums</TD></TR></TABLE>
waste of money on an Integra.
integraboosted
May 2, 2006 10:33 AM
94lsturboteg
May 9, 2005 07:08 AM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
Canttx
Jun 19, 2003 07:52 AM
