3 bolt 2.5" exhaust Gasket
Old Nov 21, 2006 | 08:39 AM
Mohsin's Avatar
Default 3 bolt 2.5" exhaust Gasket
Hello All,
I have an RS*R GT2 catback and an 2.5" Omni test pipe, will this gasket do the job:
http://cgi.ebay.com/ebaymotors...photo
Thanks
Old Nov 21, 2006 | 09:08 AM
B16b-EJ8's Avatar
Default Re: 3 bolt 2.5" exhaust Gasket (Mohsin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin &raquo;</TD></TR><TR><TD CLASS="quote">Hello All,
Thanks</TD></TR></TABLE>
I think it would work...however its not needed. I dont run a gasket between my test pipe and exhaust and have done so for over a year with no leaks or problems. If one doesnt come with your exhaust or the test pipe then one is not needed. RsR is a good company so they would have sent the gasket with the exhaust. You will however need the donut gasket for the header side of your exhaust setup if you havent already (if not you will need the 2.5" donut gaskt for a 98+ JDM ITR header or an s2000 one will work also).
Old Nov 21, 2006 | 01:39 PM
Mohsin's Avatar
Default Re: 3 bolt 2.5" exhaust Gasket (B16b-EJ8)
thanks for the reply, yeh the rsr came with a gasket, unfortunatly i need another one, will the ebay one be good? the hole centre - centre on the RSR is 79mm, the gasket is 87.5mm from hole centre - centre, will this be ok?
3Rd_gEn_LuDE
Feb 10, 2011 05:02 PM
InvaderTrax
Apr 11, 2007 02:39 PM
JDM_ITR
Oct 16, 2002 10:20 AM
