2002 Accord Check Engine Code P1676
Old Nov 21, 2006 | 07:24 AM
lorenedopp's Avatar
Default 2002 Accord Check Engine Code P1676
My Check engine light came on and I had the code read which came back with code P1676. I tried to look up everywhere what this code means and could not find it anywhere. Is it bad to continue to drive my car with the light on?
Does anyone know what this means. I have the EX V6 2002 with 48000 miles on it.
I appreciate any help you have on this.
Thanks
Loren Doppelt
Palatine, IL
lorenedopp@aol.com
Old Nov 21, 2006 | 08:15 AM
hondadude's Avatar
Default Re: 2002 Accord Check Engine Code P1676 (lorenedopp)
the code is reporting some type of fault in the Trans Control Module data line circuit.
Any shift problems? Anything else been done to the car?
Did you try to reset or erase the code to see if it comes back right away?
Modified by hondadude at 11:30 AM 11/21/2006
ddevault1
Honda CR-V & Element
May 31, 2015 02:26 PM
LoGaN-VanG
Honda Civic (2001 - 2005)
Jul 1, 2009 08:18 PM
Leets
Mar 25, 2002 08:41 PM
