Reverse blowing fuse HELP PLEASE
I have a 90 CRX DX and the other day I went to put the car into reverse to back out of my driveway. When I went back a few feet #1 fuse blew and I didnt have a tach, reverse lights, or blinkers... but I did have my hazard lights. Then I figured maybe the fuse was about to go so I replaced it. Then I started the car up and it ran fine reved it up tried the blinkers and was fine, but when I put it in reverse the fuse blew again. So I then took the under hood fuse box out to see if something had happened to the wires somewhere, but they all looked fine (wasnt sure which wires to look at though) so then I figured I would plug each plug back into the fuse box one at a time with the ignition on and when I did that the fuse blew when I plugged the ignition plug into the fuse box. Everything else was already plugged in, it was the last plug I got to. And ever since that when everything is plugged in and I turn the ignition on the fuse blows instantly now. Does anybody have any idea what could be causing this? I havent had any problems with this before and I wouldnt mind if the tach, and reverse didnt work I just need my directionals. Help me please
si0385.
20
Apr 17, 2006 08:12 AM
madcrossover
Jul 27, 2005 07:41 PM
