adjusting valves?
ok im pretty sure this is my problem .. i have a slight ticking sound coming from my valve cover.. so im guessing its just the valves need to be adjusted?? any one knows what this costs? or might it be somthing else to consider??
[Modified by shawnD, 4:03 AM 5/9/2002]
If you want to do make sure you do it right my friend thought he could do it and screwed my car, if you do it be careful and get a manual a good one but I think most places will do it for like 100 bucs mine tic too but its alot worse now my friend broke a bunh of bolts and now I have to pay a shop to fix it
so just be careful. but hey I guess I learned alot
Ahh don't be scared to do it yourself man! Like everyone here has said, get a good manual,and don't worry about it. Get a set of $5 feeler gauges, and have at it! If you do take it to a shop, make sure that they let the car cool down for a day, because even the SLIGHTEST bit of heat can throw the adjustment off!
what motor do you have? I have a B16a and mine was tickin since the swap. I thought it was the valves so i adjusted those. The ticking was still there, so I thought it was the injectors stickin, nope. Then I thought it might have been something in the distributor(wild guess), nope. So I am gonna see if its my lifters or my rockers, I just know alot of B16'ers have this common problem.
damn....i dont think you need to let the motor cool down for a day! hahaha...well he's right though...do the adjustments when the head is the coolest....like in the morning but when we did valve adjustments at the dealership we would stick a digimometer (i guess thas what it is fer short) and wait till the head temp was AT LEAST below 80 degrees F....the SOHC's are alot easier to adjust valves but the b-series motors arent bad either...When you get your feeler gauges...(since youre doing the B16) get some long ones ..like about 6in-12in feeler gauges...i have snap-on brand and they werk great to get down deep where the lobes and rockers are...also its really hard to get your wrench and flat head screw driver in the head fer the b-series motors when tightening the lock nuts...so you might wanna invest some money in a special tool or a custom deep well socket with a flat head down the middle...
and remember.....get a good manual(helm's)...try the DOHC delsol specs..should be good..werkd on mah bro's sir2 motor....GOOD LUCK!
ps....follow the manual!
what manual should i get for a b16a?
I have a b16a and I tried to do my valve adjustment the other day and couldn't do it. I think I need that special tool from snapon jam nut wrench. I used the integra GSR manual when I was going to do my adjustment. They have the b16a measurements in the book also. intake 0.006, exhaust 0.008.
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
