crv vtec motor in an integra???
what are your guys opinion of putting a crvblock with a b16a head with type r intake manifold and some other lil goodes into an integra?? my friend doesn't think its a good idea..but i see alot of people wanting to do it?? well i know someone selling the motor for 2g's and wondering if it is worth it..
$2k for a regular CRV motor? They can be had for less. The power curve is great and 200+WHP is possible with the right parts. It all depends on what you want...as a daily driven vehicle, CRVTEC would be an excellent choice.
Is it worth the money? Many would say no...but in my opinion, it's the ultimate when it comes to N/A. If you get it built right, it will be very reliable and easy to maintain (one of my main concerns).
[Modified by ALF, 12:55 AM 5/9/2002]
if you had a gsr block already ..like me...
wouldn't it be wise just to resleeve and bore out to 2.0?
any disadvantages?
any disadvantages?
The c-speed integra just went 12.8 at the track with a similar setup. b20 block, itr head. check out c-speedracing.com there's probably a lot of info there about the b20/vtec setup.
any disadvantages?
Not really. It's just that CRV blocks can be had for real cheap if you look around...to the point where boring out and resleeving your GS-R block could cost more.
any disadvantages?
what i'm sayin is..i have a GSR....
wouldn't it be wiser with all my **** in there already to just bore it out to 2.0?
crvtec ain't cheap...a block maybe..but to set all that **** up..
anyone research/look into this?
if you have a gsr than use that tranny for the crv/vtec. that saves money right there. i have it on mine and it rocks! if you only have the gsr block than you would have to buy a tranny anyway , so its not really more money-its cheaper. plus you already have the gsr head. ***you can get b20b blocks for $800 . vtec conversion line to b20 block for $75. do you already have gsr ecu?
if you bored the gsr block than you would have to mess with custom/ modified head gasket. and after all that you would still have a smaller bore and still an 87.5
stroke instead of 89mm. -----get a crv/vtec all the way!
*********plus after completing this project you can sell your gsr shortblock for at
least $300.---people are in need of short blocks all the time.
98 b20b with machined pistons only has 15k miles on it. ls vtec fitting and oil line
B16a head. rebuilt with new valve seals, type
R valves, dual valve train and retainers.
caps and valve cover ,etc.
Type R intake Manifold with throttle body
and the wire harness
all that for 2k's??? you think it is worth it......
also to complete it.. i can just use my shiftlinkage my axles and my tranny..i got a gsr so is that right??? do i have everything i need??? but is it worth 2k and do i have basiclaly a complete swap...and also i can use integra mounts right???
won't i have to go to the state ref or something because of the engine swap?
i have a 2000 gsr. don't i need to get a 2000 or newer CRV block?
i just don't wanna get pulled over and get my car impounded....
or not being able to register my car...
dayamn...crvtec is sounding better and better..
fawkin aye!!
yeah, but it wouldnt give you a considerable amount of horsepower stock. youre better off using that money and gettin a turbo.
anyways i say sell the gsr longblock keep ecu and tranny and use that $ toward the crvtech then go turbo. Gsr is great motor but it cant compare to the torque of the b20, just remember build it while its apart it will save you $$. As far as reliabilty mine has held up well its completly stock bottom end non vtec oil pump and has been on car since january. IT has went thru a s/c for about 6 weeks and now turbo for 3 weeks and no probs.
so you guys think that is a good deal
also, 2000 for a "stock" b20/vtec is not that bad. i got my b20z longblock for 1100. 700 for the complete gsr head. 300 for the obd-1 gsr ecu. actually i just paid for the longblock coz i transferred everything from my previous ls/vtec setup. but u get the idea.
if u have some more money, try to swap out the stock pistons with higher compression ones, beefy rods, arp rod bolts, etc, etc. if u don't have the money now, u can always wait till u get more funds to make ur b20/vtec into a monster. u'll save more money waiting to put the stock b20 (or crv/vtec) in ur car and having to put all the goodies in the engine while it is out.
hth.
and after all that you would still have a smaller bore and still an 87.5 stroke instead of 89mm. -----get a crv/vtec all the way!
If you keep the b18c you get the following:
better lubrication
better vtec crank
girdle
oil squirters
etc.
Right now I rev my b18c to 9k with a fully built valvetrain and stock bottom end. try that on a b20. with a fully built/blueprinted/sleeved/balanced b18c you can rev over 9k. I actually sold my b20z longblock in favor of resleeving my b18c.
jdm$product$
12
Mar 24, 2010 02:22 PM
domepeezo1
Aug 16, 2009 02:39 AM
