ZC tranny seal same as SI trans Seal?
I'm a Jackass
I wanted to know before i went to the dealer and ordered the wrong part number. or is it maybe the same as a 89 teg tranny seal?
this is for where the axles meet the tranny.
thanks
thanks
I'm a Jackass
THANKS for the input but i need a definative answer.
i guess i could take one off my old SI and see if its the same as the ZC one
I finnally found the info on the oil seals for the zc tranny !!!!!
AXLE SEAL'S:
Because the JDM L3 "ZC" tranny was paired with a 1.6l DOHC powerplant, it was designed to use the larger "Integra sized" inner CV joints with the 40mm splined shafts. The bore in the transmission casings is the same as the USDM L3 transmissions, so the outside diameter of the seals is the same. However, because of the larger caliber splined axle shafts, you will need the larger inner diameter seals.
Here are the part numbers for the seals. Your local Honda dealer can order them.
AXLE SEAL PART NUMBERS:
Left==91205-PL3-B01
Right=91205-PC9-711
AXLE SEAL'S:
Left==91205-PL3-B01
Right=91205-PC9-711
pelotudo
Aug 26, 2002 06:00 AM
