Clutch Pedal Broke
Old Nov 20, 2006 | 08:39 PM
ryanplayjoint's Avatar
Default Clutch Pedal Broke
My clutch pedal broke in my 89 crx si. I wanted to know if anyone has removed the pedal assembly before or has any tips for when I go to the bone yard. The factory manual does not have any procedures. I didn't get a good look at it becuase it happened at night. Any info much appreciated.
Old Nov 20, 2006 | 08:44 PM
1 Fly SI's Avatar
Default Re: Clutch Pedal Broke (ryanplayjoint)
How did it break. Did it fall off or does it travel to the floor and not come up,or break in half? I got a brandnew oem clutch pedal from honda for sale.
Old Nov 20, 2006 | 08:54 PM
Default Re: Clutch Pedal Broke (1 Fly SI)
Its broken at the pivot point for the pedal. I was racing and when I slammed 2nd the pedal broke apart. I quess my left leg finally got back at the exedy stage 2.
Old Nov 20, 2006 | 08:56 PM
crxnj's Avatar
heres a tip,,either take out the dash or drop the steering column to give you more space..this pedal breaking crap is common even on stock clutches..it sucks
Old Nov 20, 2006 | 08:59 PM
Default Re: Clutch Pedal Broke (mr.speaker)
1 Fly do you have a pick of the clutch pedal that you have for sale? I checked out your garage sale and did not see it?
Old Nov 20, 2006 | 09:02 PM
I meant pic, and by the way is a 90-93 integra clutch pedal the same? If I can't find one in the bone yard I will hit you up.
KFBhonda's Avatar
it happened to me. i pulled the assembly off a car in the boneyard and put it on. if you can, have the welds reinforced before you put the "new" one on.
it is just awkward to get up in there -- otherwise, the remove and install is pretty straightforward. it helps to remove the one at the junkyard first, because that way you know what to do when it comes time to take it off your own car.
Old Nov 20, 2006 | 09:12 PM
Default Re: Clutch Pedal Broke (KFBhonda)
Yeah I was thinking to practice on the boneyard one first, is it one pedal assembly and the brake & gas pedals are another assembly or is it one whole assembly? I 'll guess I'll check out and compare the DA integras pedal just for general purpose.
Old Nov 20, 2006 | 09:15 PM
KFBhonda's Avatar
it is just one whole assembly on EF's and DA's... i am 100% certain about the EF's and 90% certain about DA's
Old Nov 20, 2006 | 09:21 PM
1 Fly SI's Avatar
I can take better picture if interested.
Old Nov 20, 2006 | 09:26 PM
electric_rex's Avatar
i just pulled my old on off bent it back to normal and rewelded the spot that broke. the clutch pledal assembly is now stronger than ever.
Old Nov 20, 2006 | 09:29 PM
1 Fly is that an entire assembly or just the pedal? Cause I fucked **** up under there.
Old Nov 20, 2006 | 09:43 PM
1 Fly SI's Avatar
just the clutch pedal. It has the bushing also. It just slides on the shaft.
Old Nov 22, 2006 | 03:09 PM
So on Tuesday I got a manual pedal set-up from a 90 si for $40. It sucked getting the pedals out, but putting them in were not that bad. I didn't remove any vents or the dash. I used a deep 12 mm on a swivel all day. I did drop the steering colum, but not that bad. Now I'm thinking on doing a auto-to-manual conversion on an un-molested eg hatchback. Does anyone know how to mount the clutch resivior when doing a 92-95 manual conversion. And before anyone says "yeah, just buy a amnual, uh ha" The automatic hatches around here no one touches and go for cheap.
Old Nov 22, 2006 | 04:26 PM
toddone's Avatar
Old Nov 22, 2006 | 04:31 PM
KillSwitch's Avatar
Default Re: Clutch Pedal Broke (toddone)
well you do have to drop the steering column but you most certainly do not have to take the dash out! that would be way to much work just to get the pedal assembly out. i just did my auto to manual swap on my crx and all i did was drop the steering column and take the driver seat out and i was golden...
Old Nov 22, 2006 | 05:41 PM
Default Re: Clutch Pedal Broke (tuybotom)
I didn't take the drivers seat out, but like I said I did drop the colum. It is a must but not too bad. I acually did on some random street where the pedal broke. I was woring with the steering wheel/rack hanging out the drivers door and every and threir momma almost hit me. Oh yeah, my rex has a water leak that accumulates on the drivers floor so I smelt like a sweaty sock after I was done. Not to mention it gets cold around here before thanks giving.
But I did some searching and is it true that the markings & mounting for a 92-95 civic clutch master are on the fire wall. I'm dieing to try a auto-to-manual conversion.
And thanks for all the info from H-T!
my94d16y8coupe
Transmission & Drivetrain
Oct 18, 2011 06:41 AM
Kyle244R948
Nov 26, 2008 01:25 AM
LaOstha
Mar 15, 2006 08:19 AM
MrSmith
Sep 28, 2001 08:30 PM
