JDM SiR cluster in my 90 CRX Si
Old May 8, 2002 | 06:23 PM
rasta420's Avatar
Default JDM SiR cluster in my 90 CRX Si
how hard is this cluster swap? what wiring changes do i need? will my speedo cable work? i think its an electronic VSS, so what would i need to do?
thanks
p.s. - anyone already with this setup, please help!
Old May 8, 2002 | 06:27 PM
EP3_05's Avatar
Default Re: JDM SiR cluster in my 90 CRX Si (rasta420)
Check this out:
http://students.washington.edu/markpaco/sircluster.html
Old May 8, 2002 | 06:50 PM
customx_'s Avatar
New User
Default Re: JDM SiR cluster in my 90 CRX Si (91civic)
or this:
http://b16a.honda-perf.org/cluster.html
Old May 9, 2002 | 05:16 AM
SuperCivic's Avatar
yeah, those sites will help a lot. you actually have to cut and splice a few wires but if you use common sense it's not bad at all. as far as the speedo..down on your tranny there is the VSS..it's really simple to pull out..one or two bolts. you can exchange it with a 92-95 d series VSS then you just hook up the three wires. a few of the things are a pain in the butt and take extra work if you want them..the door open lights, the low fuel light, etc.
Old May 9, 2002 | 05:49 AM
ricodemus's Avatar
yeah, the second site is updated I believe to cover all the wires. I have an SiR cluster sittin around, I just haven't went to the install yet because finishing my b16 swap is priority, then the brakes, then the cluster.
Old May 9, 2002 | 06:17 AM
SuperCivic's Avatar
Default Re: JDM SiR cluster in my 90 CRX Si (ricodemus)
yeah, i switched from an 89 cluster to a 90 crx cluster to go with my dash, then after i did my b16 i put in the SiR cluster..makes sense when the B16 tranny (at least mine did) came with an electronic VSS, so all i had to do was wire it up.
Old May 9, 2002 | 09:07 AM
rasta420's Avatar
Default Re: JDM SiR cluster in my 90 CRX Si (SuperCivic)
well i have a d16a6, so how hard is wiring going to be for me?
Old May 9, 2002 | 09:26 AM
SuperCivic's Avatar
not that bad at all. you have the plugs for the SiR cluster, right? there's four of em. you need the electronic VSS though. get it from a junkyard or something..
just take your time and follow the charts that people have made.
Old May 9, 2002 | 09:36 AM
88_SC_CRX_Si's Avatar
New User
One of the peeps over on the Resource just swapped out the gauges only. That way he did not have to do any re-pinning...
Old May 9, 2002 | 09:37 AM
SuperCivic's Avatar
Default Re: JDM SiR cluster in my 90 CRX Si (88_SC_CRX_Si)
seriously, repinning is not that hard. you just use a very small screwdriver to get the pin loose from the plug it's in..then use the chart to figure out where it goes on the other cluster, then plug it in. not that hard..
Old May 9, 2002 | 09:49 AM
rasta420's Avatar
i dont have the SiR plugs for the cluster either...
besides the SiR plugs, i need the fuel level sensor, the electronic VSS, and the wires for the doors, correct? where would i get the fuel level sensor and the electronic VSS that would fit my 90 crx si?
[Modified by rasta420, 6:51 PM 5/9/2002]
Old May 9, 2002 | 10:08 AM
SuperCivic's Avatar
ouch..you really do need a set of those plugs..not sure, maybe other usdm civics use the same plugs?? the VSS you can get from a 92-95 civic..shouldn't matter what trim. fuel sensor can be gotten from a 91 teg i believe..same w/ door sensors. i would worry about the VSS and the plugs first.
Old May 10, 2002 | 09:02 AM
rasta420's Avatar
would the electronic VSS from 92-95 civic fit in my ZC tranny? thats where it goes, correct?
Old May 10, 2002 | 10:49 AM
Overkll's Avatar
Yes, the VSS will work on the ZC. It fits exactly the same as the mechanical, just uses a wire to the sensor in the dash, instead of a cable (spring). REALLY easy to get to on the backside of the tranny, just take off your intake and move some wire loom. HTH, Overkll
Old May 10, 2002 | 02:01 PM
ruiner17's Avatar
yea..the wiring was easy. especially since you have a 90 (i have an 88). the hard thing for me is getting the stock vss out of the tranny. i've tried numerous times, but the damn thing seems to be stuck. i removed 1 pin and 1 bolt, and it still won't budge... perhaps there's another bolt down there...but i haven't found it.
any suggestions?
thanks for the help...
Old May 10, 2002 | 05:15 PM
rasta420's Avatar
Default Re: JDM SiR cluster in my 90 CRX Si (ruiner17)
so your speedometer doesnt work? did you get the little CRX picture to work (doors, rear hatch)? what engine do you have? where did you get your plugs from?
ronwilliams
May 26, 2011 09:53 PM
blasterman87
May 9, 2010 07:47 AM
urafag
May 14, 2006 12:39 PM
jdmhondas
Oct 1, 2004 02:17 PM
bardo
17
Jan 25, 2004 08:07 PM
