CRX, Bumper-Headlight removal
Old Nov 20, 2006 | 06:51 PM
0bd1_Kanobe's Avatar
Default CRX, Bumper-Headlight removal
Never had a EF before and im getting ready for a intercooler install. How do you remove the healight's? Try to wiggle them out and would not budge . Any input would be helpfull.......Thanx
Bump cause i need to get this done!!!!!!!
Old Nov 20, 2006 | 06:52 PM
d16vtecx's Avatar
Default Re: (0bd1_Kanobe)
I take off the bumper first then go from there
there may be an easier way
Old Nov 20, 2006 | 06:53 PM
JustAnotherRex's Avatar
Edit - **** I thought you meant removing the bumper then the regular headlights.
I'll go back to my hole now.
Old Nov 20, 2006 | 07:19 PM
LOL, how would I go about removing the bumper. I know it has to screws on each side by the tire's and there are about 4 more by the radiator. What else am I missing........?
Old Nov 20, 2006 | 07:29 PM
bump
Old Nov 20, 2006 | 07:31 PM
bump it
Mugencrxsir1's Avatar
Nothing else, just the 2 screws in each fender well, and the 3 screw by the latch in the middle. It's pretty simple, but if it's not coming off it's because you have to wiggle each side of the bumper to get it loose from the plastic peice that the bumper screws into. Don't be afraid to man hand your stock bumper, it's pretty flexible, you kind of have to peal the bumper away at the fenders. Then the bumper should just fall off, sorry I'm have trouble explaining what to do. It should'n take more than 2 secs once the screws are all out. goodluck
Old Nov 20, 2006 | 07:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0bd1_Kanobe &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old Nov 20, 2006 | 07:33 PM
Thanks will try that method
Old Nov 20, 2006 | 07:50 PM
boosted.CRX's Avatar
Your forgetting the screws hidden behind the corner lights. Unbolt the corners (one bolt, ontop of them under the hood) then slide the corners out(pull away from front of the car) and you will see one more Phillips.
Old Nov 20, 2006 | 08:06 PM
Yeah noticed that the bumper was caught around the corners...Good Info Thanx
Old Nov 20, 2006 | 08:57 PM
1 Fly SI's Avatar
That is the hard way. Just take the screws off in the inner fender by the tires and then take out your bumper lights. There is 2 ten millimeter bolts behind each light. Take them out and the entire bumper and support comes off. Then you can get to the hidden bolt on the bottom of the headlight that is holding it on.
Old Nov 20, 2006 | 08:58 PM
IP RACING's Avatar
when I put in my headlights on my 90 sedan.. I removed the screws from the wheel wells two on each side.. I removed the turning lights... then took off the bolts that were behind that.... then just wiggled the bumper a bit and it pulled right off.... I would assume its the same thing.. I got my headlights off of a crx in the junkyard
Old Nov 27, 2006 | 11:16 PM
Bumper is off, thanks for the info. Would post a pic of why I wanted to take it off but dont know how to re-size it!!!
JacksonD
Mar 3, 2010 08:30 PM
Jer'rome
Honda Civic (2001 - 2005)
May 27, 2007 05:57 PM
95se4dr
Aug 5, 2004 10:39 PM
ForceXVII
Aug 29, 2003 11:21 AM
CHRIS 1.8
12
Apr 27, 2003 07:43 PM
