Y8 and Z6 came gear same/interchangeable?
Old Nov 20, 2006 | 06:27 PM
RNPoo7's Avatar
Default Y8 and Z6 came gear same/interchangeable?
Will the cam gear interchange?
specificially will an AEM cam gear from y8 work on z6 head?
Thanks in advance.
Old Nov 20, 2006 | 10:10 PM
Enzo_Speed's Avatar
Default Re: Y8 and Z6 came gear same/interchangeable? (RNPoo7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNPoo7 &raquo;</TD></TR><TR><TD CLASS="quote">Will the cam gear interchange?
Thanks in advance.</TD></TR></TABLE>
Yes, but there's a catch. You have to adjust the gear to compensate for the new woodruff key location.
What that means is that you have to loosen the bolts on the gear and rotate it a few degrees (3 I think?) in order for the engine to operate normally.
Old Nov 21, 2006 | 06:20 AM
b18sihatch's Avatar
just get the z6 unless you wannaa have to deal with adjusting the cam gear
90LSpimpin
Jan 31, 2005 01:34 PM
tai93si
Apr 24, 2004 02:03 PM
