is this the easiest swap for a 89 civic hatch
Old Nov 20, 2006 | 05:53 PM
ap1$2k's Avatar
Default is this the easiest swap for a 89 civic hatch
or should i wait for an LS motor, does the torque in the LS better than the horsepower the b16 offers
http://hmotorsonline.com/shop/...30002
Old Nov 20, 2006 | 06:29 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: is this the easiest swap for a 89 civic hatch (ap1$2k)
hahah you just opened a can of worms, it's a non stop debate, search up and make up your own mind what works better for you.
LS will be easier then a b16 *just because of vtec wiring and thats far from hard*
So i'd put them on the same level for a swap.
good luck
Old Nov 20, 2006 | 07:04 PM
d16vtecx's Avatar
Default Re: is this the easiest swap for a 89 civic hatch (Capt. Blonde Beard)
i would go with the LS cuz you can always add a vtec head later
Old Nov 20, 2006 | 09:22 PM
ap1$2k's Avatar
its way more expensive for the ls than the b16 thru hmotors, this car wont be driven much except for in the winter and i plan on goin turbo anyway is why i was thinking of b16 jus because thats the motor that was originally in the car in japan so i figured it was easier
Old Nov 20, 2006 | 10:11 PM
ap1$2k's Avatar
is the b16 mentioned above a direct swap with everything they ship mentioned in the ad
Old Nov 20, 2006 | 11:02 PM
crxnj's Avatar
Default Re: (ap1$2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1$2k &raquo;</TD></TR><TR><TD CLASS="quote">is the b16 mentioned above a direct swap with everything they ship mentioned in the ad</TD></TR></TABLE>
no. you need mounts,linkage,minor wiring,minor denting
what car do you have? si or dx or std?
bbrian
39
Aug 4, 2012 05:48 AM
lrcrx90
16
May 3, 2006 12:50 PM
jdmsiblue1
Jan 30, 2006 06:06 PM
boostedeghatch
May 6, 2005 04:54 AM
tunerboy03
Aug 23, 2004 11:18 PM
