Should the downpipe have a hanger?
Old Nov 20, 2006 | 02:18 PM
HondaHeddie's Avatar
Default Should the downpipe have a hanger?
After market headers are not uniform. Some have hangers that attach to the rear block point and some have no hanger points at all.
I asked about my hangerless header earlier and would like to see what the opinion of the group is.
Old Nov 21, 2006 | 04:59 AM
fireant's Avatar
Default Re: Should the downpipe have a hanger? (HondaHeddie)
Motor mount inserts and a properly fit exhaust after the header helps to keep the engine movement to a minimum, so if you can spring for the motor mounts from Energy Suspension (very cheap mod) it should reduce the strain on the header bolts.
Personally the extra support was one of the reasons I went with DC over Megan... but Megan is also an excellent d-series header.
http://www.hondaworkshop.com/dc-vs-megan/
Old Nov 21, 2006 | 09:43 AM
Default Re: Should the downpipe have a hanger? (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Motor mount inserts and a properly fit exhaust after the header helps to keep the engine movement to a minimum,
http://www.hondaworkshop.com/dc-vs-megan/</TD></TR></TABLE>
When I swapped the exhaust for the header I have now, the fit was perfect.
I will check on the mounts, thanks. I will keep pics for the mount swap if I go that way.
I have a Megan style header (no hanger and made of SS)
Great link too.
43!
K Series
Mar 16, 2017 08:13 AM
ShinyNewPenny
38
May 24, 2009 08:12 PM
kobeballer96
11
Feb 20, 2009 02:21 PM
iVteCmMdc5
20
Mar 12, 2008 11:31 PM
RHardin15
Mar 28, 2007 05:49 PM
