92 accord auto to manual (almost done!)
I had a 92 dx accord auto had slipping problems so I decided to do a f22a1 5 speed transmission swap, I have everything done and the transmission is in also, I want to get better mounts that fit better on the transmission side cause it seems to sit the tranny a little bit to the firewall and its rubbing on the rear crossmember where the rear engine mount is located at don`t know the exact name for it.
I havent started the car yet but I`m pretty sure I have the correct pin for the shifter assembly connected properly I connected pin #2 (green wire) to pin #5 ( black wire) and the other remaining harness with two big black wires I connected those but I havent started the car yet still not done putting everything back together since I did it at a friends house and I live like 30 mins away since my apt complex is strict about working on cars so I`ll find out I guess when I finish.
So just the wiring pinning making sure I did it correctly and I wanted to get a 2nd opinion those who know or have done it and the transmission motor mount issue, does anybody know any good after market possibly or a trick to modify the transmission mount so it fits better?
customcarkids
Feb 3, 2005 06:43 PM
