want your opinon!
Old Nov 20, 2006 | 12:03 PM
oMek's Avatar
Default want your opinon!
i bought my gsr with 148k miles 3 years ago. it now has 168k and is due for a oil change...
ive been usein castrol 10w-30 syntec. ive always had a problem with alittle oil getting burnt but this last 1kmiles ive burnt up alot more than normal.
will i have any drawbacks by going back to con oil? or should i stick with the syntec?
Old Nov 20, 2006 | 12:52 PM
mac_24_seven's Avatar
Default Re: want your opinon! (oMek)
No drawbacks at all mang.
Old Nov 20, 2006 | 06:28 PM
red01teg's Avatar
At least bump up to 10w-40...theres no drawbacks to going concentrated.
Old Nov 20, 2006 | 10:12 PM
SoTexDC2's Avatar
If your engine is consuming oil, you might actually benefit from switching to conventional. Try not to veer too far from OEM Spec Viscosity, unless the consumption does not improve. It will cause your engine to feel more sluggish than usual.
Old Nov 20, 2006 | 10:24 PM
Blk-dc2's Avatar
Default Re: (SoTexDC2)
i have the same problem, but i switched to a full synthetic (mobil 1)
and i saw a big change in the amount of oil i was having to put in my car...
thats just me...
also my problem is i have bad piston rings (i think)
Old Nov 20, 2006 | 10:43 PM
Fat Chick Magnet's Avatar
if you want to burn less oil use valvoline full synt. oil 20w50. trust me on this one. i used it couple of times.
20w50 sounds heavy as f$#%, but it works especially the valvoline full synt oil.
Corruption
Aug 23, 2006 06:52 AM
redLUDEs2k1
Oct 12, 2005 10:21 AM
elmoTypeR
Feb 21, 2005 04:08 PM
HybridGSR1
Jul 4, 2003 07:37 AM
