Fuel system for my ef swap?
Swapping in a b18b1 in my ef sedan. Its built up a little bit. probably going to be putting down in the area of 160-175. Will the stock fuel pump handle this?
also, I have a set of injectors that I was told came from an integra type r. What size injectors are these? Is there a difference between jdm and usdm type r injectors? and are stock injectors low or high impedance. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky »</TD></TR><TR><TD CLASS="quote">
also, I have a set of injectors that I was told came from an integra type r. What size injectors are these? Is there a difference between jdm and usdm type r injectors? and are stock injectors low or high impedance. thanks!</TD></TR></TABLE>
resistance is dependant on the year of the car some are high some are low
heres a good page http://www.robietherobot.com/s...e.htm
also you can tell by the plug fo the injector, they are different..
i would go with a 190lph..ran a 255 in my old ED till i sold it, it was noisy and i added a 30amp relay for the extra amperage needed..you dont have to but I rec it..it kept on burning up my plugs and wires before the relay.. :shrugs:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky »</TD></TR><TR><TD CLASS="quote">One of the main reasons I ask is becuase...I need to know if I need to run a resistor box. which I dont want to have too do. Becuase I have a full harness from rywire.</TD></TR></TABLE>
