Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Oil Change Display Question
Old Nov 20, 2006 | 08:14 AM
1oldroaddog's Avatar
Default Oil Change Display Question
I just changed the oil in my Civic; the Helms manual shows how to reset the "Oil Life" display BUT the manual also says to note what else may be displayed that may require service.. When resetting the display I got a "B1" code. The Helms manual shows A and B type service items but no number... Anybody have any idea what "B1" means?
Thanks!
Old Nov 20, 2006 | 11:03 AM
TRE_'s Avatar
Default Re: Oil Change Display Question (1oldroaddog)
Its basically a Oil change, tire rotation and saftey check:
B1:
Oil / filter change
service/adjust rear & front brakes
rotate tires, inspect for wear and proper PSI
inspect parking brake/adjust
inspect tie rod ends, steering box and boots
inspect suspension components
inspect driveshaft boots
inspect brake hoses / lines
check all fluid levels/conditions
check for leaks
inspect exhaust system
inspect fuel lines/connections
Old Nov 20, 2006 | 11:10 AM
liketofry's Avatar
Default Re: Oil Change Display Question (TRE_)
Correct me if wrong. Looks a lot like what they do on the 15,000mi service? As your miles progress do the codes change? Say like when I hit 30,000mi will it provide a different code?
Old Nov 20, 2006 | 11:45 AM
TRE_'s Avatar
Default Re: Oil Change Display Question (liketofry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liketofry &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if wrong. Looks a lot like what they do on the 15,000mi service? As your miles progress do the codes change? Say like when I hit 30,000mi will it provide a different code? </TD></TR></TABLE>
Yes, basically a 15k/45k/75k service
30k service TYPICALLY(depends on dealership) includes much of the same + replacement of air cleaner, brake flush, coolant flush, trans fluid, valve adjust, hepa, etc
There will be a different maint. code when a 30k service is required.
Old Nov 20, 2006 | 11:56 AM
liketofry's Avatar
Thanks, always wondered what those codes meant.
Old Nov 21, 2006 | 02:32 PM
LxRacer's Avatar
u just got mine done $153 cdn l
dohc-father
Jun 23, 2009 11:20 AM
Plastic Fury
Nov 14, 2008 10:37 AM
ComptonsF1NEST
Acura TL, RL & ZDX
May 14, 2007 07:31 PM
jayturboef
Apr 15, 2007 02:49 PM
HotDC5
Apr 19, 2005 10:17 AM
