Hid projectors?
Old Nov 19, 2006 | 11:24 PM
Jhonny Ricer's Avatar
Default Hid projectors?
So im replacing my headlights and want to swap to HIDs so im not sure where to get the housings that ARE ACTUALLY HID compatible not the crap ones that say they are but they are ebay specials just trying to get the money i need headlights that are made and have proper cut of so on
plz help
Also what in the hell are these headlights that are so called "projector" headlights are they actaully what i need for the hids and why are there two bulbs sorry for the stupid questions but i just want a headlight that looks good and is Hid compatible thasnks for any help
Old Nov 20, 2006 | 12:24 AM
Default Re: Hid projectors? (Jhonny Ricer)
up
Old Nov 20, 2006 | 02:55 AM
Import_Fan's Avatar
Projector: (S2000)
Non-Projector: (IS300)
To the best of my knowledge, in order to get a real OEM HID compatible setup you need to either buy it from the parts department (mucho $$$), salvage it from a wreck at the junkyard, or you can scour ebay. Both the IS300 and S2000 are designed for HID in their headlamp unlike a civic for example. The reason for two bulbs would be, I think, bi-xenon HID, being that your high beams are also HID. Personally, I think high beams should stay as regular Halogens cause once you get true HID you rarely need to use your high beams any more. That, coupled with the fact that HID takes a few moments to heat up, and should not be flicked on and off rapidly, are not favorable conditions for HID in the high beams.
Old Nov 22, 2006 | 03:30 PM
prelude1897's Avatar
You're probaby thinking of Retrofits which is what you'll need done to your car in order to have the HIDs work properly with your car. If you need some projectors, I have some E46 Bi-xenon projectors(BMW) I can sell you. I've been doing retrofits for people for about 3 years now and have plenty of vouchs for my work
Old Nov 22, 2006 | 04:08 PM
velocity's Avatar
Default Re: Hid projectors? (prelude1897)
yep retrofit is the way to go
Old Nov 22, 2006 | 04:13 PM
aaronISthrowed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">You're probaby thinking of Retrofits which is what you'll need done to your car in order to have the HIDs work properly with your car. If you need some projectors, I have some E46 Bi-xenon projectors(BMW) I can sell you. I've been doing retrofits for people for about 3 years now and have plenty of vouchs for my work</TD></TR></TABLE>
^this man does a good job.
Old Nov 22, 2006 | 04:23 PM
Thizzed Out's Avatar
Default Re: Hid projectors? (aaronISthrowed)
keep ur stock headlights, and just do an retrofit..its kinda hard but youll get it done. hidplanet.com is a good place to buy hid's there is also forums to help u out. thats where i learn how to retro fit. Good Luck
Old Nov 22, 2006 | 06:05 PM
jbell's Avatar
Default Re: Hid projectors? (thizzed_out_civic)
i have 1 s2000 projector for sale...
actually.. the whole headlight.
Old Nov 22, 2006 | 06:18 PM
Default Re: Hid projectors? (jbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">i have 1 s2000 projector for sale...
actually.. the whole headlight.</TD></TR></TABLE>
how much are you asking for those?
Old Nov 22, 2006 | 06:23 PM
jbell's Avatar
$200.
Old Nov 22, 2006 | 06:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">$200.</TD></TR></TABLE>
does that include all parts(bulbs, ballast, projectors)? Do you have any pics?
Old Nov 22, 2006 | 06:50 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">does that include all parts(bulbs, ballast, projectors)? Do you have any pics?</TD></TR></TABLE>
http://img124.imageshack.us/img124/8673/hidyo3.jpg
its for just the bare headlight.
i hit a deer. broke my hand too, so excuse the shitty tag.
its a 2005 headlight. its mint except for the mounting tabs.. they snapped, so the light bounces around.
Old Nov 22, 2006 | 08:55 PM
you got lucky with that fuggin deer
Thanks for all the posts like jbell my car got into a litlle fiasco with a bear last night so umm yea the hid conversion is going to wait until spring when i get the 99-00 conversion for my front end thanks all and if you still have parts or are willing to do the retrofit let me know
Old Nov 22, 2006 | 08:58 PM
also another question is
is there a way to make my retro fit have a "high beam i know that all the low beam is a cut off but is there a way to put that cut off cover in there so when im in deer country i can have them cut off higher per say sorry if you cant understand me im having a hard time explaining things
Old Nov 22, 2006 | 09:19 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">also another question is
is there a way to make my retro fit have a "high beam i know that all the low beam is a cut off but is there a way to put that cut off cover in there so when im in deer country i can have them cut off higher per say sorry if you cant understand me im having a hard time explaining things </TD></TR></TABLE>'
bi-xenon?
slowpokecivic's Avatar
get a bi-xenon setup...
and o yea, a bi-xenon only uses one bulb...the projector itself moves the shield and lets thru more light...
Old Nov 23, 2006 | 08:00 PM
Default Re: Hid projectors? (SLoWpOkECiViC)
thats what i needed to know thank you very much all
Old Nov 23, 2006 | 08:02 PM
ff terror's Avatar
too old for school
once you got hid you'll never go back... youve been warned
Old Nov 23, 2006 | 08:09 PM
j_kevin_ca's Avatar
or tyc projectors... not bad for aftermarket projectors
thatoneguyyy
Lighting
Oct 11, 2012 09:33 PM
turboman
Lighting
11
Jul 14, 2008 08:07 AM
ChaseIntegra
Jan 19, 2005 05:19 AM
tekstyle
Nov 12, 2002 09:11 AM
