Transmission Halves
i couldn't get that bloody clip around the bearing when i put the case back together, (im referring to that clip that holds the shaft to the case at the top of the case that you have to spread in order to slide the case apart. so far the case seal is fine and i should be starting her up soon. the clip was less than a 1/16th from the place its supposed to be so I dont think it will cause much trouble, or it will pop in on its own. any thoughts?
c-techracing
Jul 7, 2007 10:56 AM
MAD SCIENTIST
Jun 8, 2003 06:26 AM
blackfrohatch
14
Jan 5, 2003 05:40 PM
