EH with B-series TORQUE MOUNTS.
Ok, so I purchased a 92 Civic DX with a thrown together b18b1 swap. It's missing the torque mounts, the ones that bolt under the frame of the car and then to the front of the motor/tranny. My question is...... How bad for the drivetrain is it to keep driving it without these mounts? The motor doesn't move much from what I can see, and it hasn't fallen out yet. Also, can I buy these anywhere? I need the stock civic ones that go under the frame and the Integra ones that bolt to the block, correct?
Appreciate any help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schpootypie »</TD></TR><TR><TD CLASS="quote">c'mon...</TD></TR></TABLE>
Did you not read?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">its bad for the other mounts. if you keep driving all the rocking of the motor is gonna tear apart the other mounts. </TD></TR></TABLE>
Now stop bitching
Did you not read?
Now stop bitching
do yourself a favor find them because i had a delsol with a b16/ctr head and quite a few mods i pulled the bolts right out of the block on the driverside mount and tore the mount....then fixed it and did the same thing about 4 months later.....everytime the bolts pulled out i also dropped the engine and broke axle, jumped timing and dented my oil pan.....fixed it and put it torque mounts....never happened again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
Did you not read?
Now stop bitching </TD></TR></TABLE>
I hate you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowrhd »</TD></TR><TR><TD CLASS="quote">do yourself a favor find them because i had a delsol with a b16/ctr head and quite a few mods i pulled the bolts right out of the block on the driverside mount and tore the mount....then fixed it and did the same thing about 4 months later.....everytime the bolts pulled out i also dropped the engine and broke axle, jumped timing and dented my oil pan.....fixed it and put it torque mounts....never happened again
Thank you.
Did you not read?
I hate you.
Thank you.
