Compression Check...??
Old Nov 19, 2006 | 10:00 PM
JFG Kevin's Avatar
Default Compression Check...??
SET UP:
84.5MM MANLEY 12:5 PISTON
GSR HEAD
LS CRANK
Around what compression should i be seeing with that set up? I'm almost sure it's not going to be at 12.5?
Old Nov 19, 2006 | 10:35 PM
s2kdre's Avatar
Default Re: Compression Check...?? (JFG Kevin)
310+ my friend had 12.6:1 and it went way past the max on the guage.
Old Nov 19, 2006 | 10:36 PM
Combustion Contraption's Avatar
you bought a 12.5:1 piston but what p2d height was that measured with?
Old Nov 19, 2006 | 10:50 PM
JFG Kevin's Avatar
Default Re: (Combustion Contraption)
Bore Size - 84.5mm/3.327"
Rod Length - 5.394"
Stroke - 3.504"
Comp. Distance - 1.181"
Dome Volume - 4.8
Compression Ratio - 12.5:1
Piston Style - Dome
Pin Diameter - .827" x 2.250"
yrpin5th
51
Dec 29, 2008 05:36 PM
B18 CYA
11
Jul 28, 2006 06:24 PM
regamaster
12
Mar 18, 2004 04:59 PM
pooonastick
Jan 22, 2003 04:03 PM
