"4gen prelude foglight wiring"???????????????????
Old Nov 19, 2006 | 07:37 PM
popRAWvtec's Avatar
Default "4gen prelude foglight wiring"???????????????????
yo! has anyone found out how to wire up the 4gen lude foglights? Help! need info.
Old Nov 19, 2006 | 07:42 PM
M2B4's Avatar
Default Re: "4gen prelude foglight wiring"??????????????????? (popRAWvtec)
umm ur 4th gen is prewired for fog lights...get a relay and your done
well plus a switch
Old Nov 19, 2006 | 07:43 PM
nonvteclude's Avatar
has been done many many times. and covered many many times
Old Nov 19, 2006 | 07:45 PM
popRAWvtec's Avatar
how do i locate the harness from the inside?
Old Nov 19, 2006 | 07:46 PM
M2B4's Avatar
under the steering wheel. find the blue taped connector plug ur relay into that. run you ur switch. then plug ur fogs in and mount....
Old Nov 20, 2006 | 03:32 AM
WhiteBB2's Avatar
Default Re: "4gen prelude foglight wiring"??????????????????? (M2B4)
HOLY JEBUS!
This is getting old. Theres a red MF'in search button at the top right...IT DOES WONDERS!!!!!!!
Anyway...On the helping side. Heres a break down for you!
1.) Locate the relay harness located way up under your dash taped with blue tape to another bundle of wires.
- Buy an Autozone relay, The brand is PILOT and costs 3.99
2.) Find the switch connector located behind the tweeter cover (in 92-93) or taped with blue tape to the hazard light switch (in 94-96)
- Get an OEM switch and plug it up where ever your switch connector is.
3.) Mount/Install the foglights into the bumper.
4.) Connect the foglights up to the foglight harness that is taped to your bumper lense wireing harness.
- This will also be connect with blue tape.
5.) Make sure there is a fuse in the kickpanel fuse box
- This fuse is a 15amp fuse and goes into the #3spot.
6.) Once you have all 5 of those steps done...turn your headlights on...and then press your foglight switch that you installed in step 2.
Done.
Black Diamond
12
Mar 5, 2011 06:12 PM
dacrxguy
Aug 12, 2009 05:04 PM
y0whuddupb
Nov 17, 2006 06:58 PM
OEM_ASSASSIN
Sep 24, 2005 04:33 PM
Fly1865
Feb 29, 2004 11:18 AM
