which drag radial grips the best
Old Nov 19, 2006 | 04:59 PM
slowsol95's Avatar
Default which drag radial grips the best
i am wanting to know what drag radial grips the best. the ones i am looking at are the 205/50/14 bfg drag radial and the 205/55/14 nitto nt555r drag radial, but i'm open to other suggestions.
Old Nov 19, 2006 | 05:21 PM
Tippyman's Avatar
Default Re: which drag radial grips the best (slowsol95)
I plan on getting the BFG's.
Old Nov 19, 2006 | 05:25 PM
A.E Motoring's Avatar
Default Re: which drag radial grips the best (Tippyman)
get BFGs
Old Nov 19, 2006 | 05:33 PM
h22 civic's Avatar
Default Re: which drag radial grips the best (Dual Cam Racing)
m/t or bfg hoosier
Old Nov 19, 2006 | 05:34 PM
Boner_Ben's Avatar
For 14's definitly go with the bfg's.
Old Nov 19, 2006 | 05:35 PM
Blueallie's Avatar
I use bfg. It dropped my 60ft 3 tenths 2nd time out. and they seem to be lasting.
Old Nov 19, 2006 | 05:36 PM
boostedh22a's Avatar
M/T's
Old Nov 19, 2006 | 05:38 PM
slowsol95's Avatar
m/t, hoosier, and m&h doesn't have a size for 14 inch rims and i am planning to put these on some steelies. what kind of 60' times are you guys pulling with your bfg's. a guy on turbod16 (jfk) pulled a 1.8 60' with his nitto drag radials and i was wondering if i could get into the 1.8's. also, how hot do the bfg's like to get when you run them, and how big of a burnout should i do?
Old Nov 19, 2006 | 06:18 PM
I would get the right wheel so your selection of tires is much better. I would much rather shop for the best tire for my combo, not the only tire that fits my wheel.
But BFG's aren't bad, I just wouldn't say they hook the best??
Old Nov 19, 2006 | 06:24 PM
A2gt35r's Avatar
BFG's don't hook worth a damn, but then what does fwd. I'm going wuth MT's 235/60/15,so we'll see.
Old Nov 19, 2006 | 06:52 PM
fmfkid250's Avatar
1.82 60' on 225 bfgs
lasted 9,000 miles on a 260whp lst hatch
Old Nov 20, 2006 | 05:09 PM
JDMisGOOD's Avatar
Default Re: (fmfkid250)
The Mickey's or the BFG's
Old Nov 20, 2006 | 06:49 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">The Mickey's or the BFG's </TD></TR></TABLE>
My BFG's hook decent.
Old Nov 21, 2006 | 07:56 PM
dj4monie's Avatar
Default Re: (boostincoupe)
BFG's do hook decent to good, depending on several things. Don't expect to get the best out of them if your car isn't setup to run them sucessfully.
Just bolting them on makes an improvement, but getting down below 1.9 on them takes some talent behind the wheel and decent suspension/driveline tuning...
Old Nov 21, 2006 | 08:16 PM
BoostedJeff's Avatar
Default Re: (dj4monie)
for 15s go hoosier, they grip
Old Nov 22, 2006 | 08:30 AM
DSMu4ia's Avatar
Default Re: (BoostedJeff)
Link to the hoosiers?
Old Nov 22, 2006 | 10:38 AM
ExVtec's Avatar
[/threadjack]
What about something on a 17 rim?
bfg's still?
Old Nov 22, 2006 | 12:21 PM
HondaPowered1320's Avatar
Default Re: which drag radial grips the best (ExVtec)
m/t
Old Nov 22, 2006 | 02:41 PM
JuanK20's Avatar
Default Re: which drag radial grips the best (HondaPowered1320)
i would go with 225 instead of 205. a lot of my all motor friends have gotten 1.8 60' ft on 225/50/15. but im not sure if they make 225 for 14's tho
Old Nov 22, 2006 | 02:47 PM
Tippyman's Avatar
Default Re: which drag radial grips the best (JuanK20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuanK20 &raquo;</TD></TR><TR><TD CLASS="quote">i would go with 225 instead of 205. a lot of my all motor friends have gotten 1.8 60' ft on 225/50/15. but im not sure if they make 225 for 14's tho</TD></TR></TABLE>
They make 215's. I'm getting the 205's though cause I don't think the 215's will fit my 5.5" steelies I got to mount the BFG's on.
Old Nov 23, 2006 | 05:46 AM
RMXmitch's Avatar
BFG D/R FTW
Old Nov 23, 2006 | 08:10 AM
Kev-turboEJ1's Avatar
Default Re: (RMXmitch)
The BFG's work pretty good for me. I just gotta learn how to drive a lil better and lower my 60ft times.
BFG drag radials
Old Nov 23, 2006 | 08:16 AM
boostfeen's Avatar
..MT or BFG in that order
Old Nov 23, 2006 | 08:53 AM
Boner_Ben's Avatar
My 225 bfg's hooked better than a set of 26" M/T's I tried out.
Old Nov 26, 2006 | 10:34 AM
Teamdiesel's Avatar
My BFG drag radial didn't hook up a I thought they would. I use to get 2.3 60ft before on snow tires, and with the BFG's I only managed a best 2.2 60 ft
