need input from mechanic
My engine sound like turbo charger installed but I don't have one. plus my whole driving cabin vibrate too.
so far my car being inspect by 2 shops, but no one can find whats wrong with it, My cylinder head shaved and replace the head gasket.
timing belt not tight, not loose I can move 1/8 on the cam gear by using 4 fingers
balancer shaft align on the money
valve adjusted (by me, its tick when cold start, as it's warm up go away)
no exhaust leak anywhere
engine mount looks fine.
idle fine 800 rpm
no check engine light
I can drive car no problem, its pulling really strong.
when its idling no noise or vibrate, but as I give more gas when its hit 2000rpm or above then the noise and vibrate.
I feel noise coming from the engine bay driver's side of the engine.
what could be the problem?
what should I check?
can EGR valve create problem like this ?
Thanks in Advance
ujhonda
idle fine 800 rpm
Thanks in Advance
ujhonda
I already check the vacuum leak, by using crab cleaner, but no vac leak, I also check the rear engine mount - disconnecting and connecting vacuum solenoid - it goes tick, tick, when I unplug and plug.
should I replace all my mount (OEM or After market), hop not cost my arm and leg, right now I am not working, job hunting.
what is the best After market mounts I should go with ?
Thanks for all the help
ujhonda
ujhonda
Well, Dont know if its the same thing,But on my 90 accord, my trans torque converter was messed up, and when i would accelerate or decelerate it sounded like a super charger whining...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro »</TD></TR><TR><TD CLASS="quote"> when i would accelerate or decelerate it sounded like a super charger whining...</TD></TR></TABLE>
Thats what that sound is?..lol
I remember when my trans was near its death that noise came a month before it died, But when I got it rebuild it still had that noise.
I have no real shifting issuses but that nosie is there? is that bad?
I don't think it's my tranny because, it roar like turbo charger even when I am on park or N,
so
I think it's my rear engine mount (one that electronic control), man I hate that, how I am going to remove it, when I can't see the dann thing.
so
ujhonda
Nov 13, 2006 09:21 PM
