forged pistons vs. cast pistons
Old May 8, 2002 | 03:05 PM
743power's Avatar
Default forged pistons vs. cast pistons
Is there any huge advantages to forged pistons (toda, endyn) over cast pistons (ctr or balanced jdm itr) on an all motor car? I haven't seen any thing happen to cast pistons that didnt happen to a forged one. Also, I would think that the coating on the honda type r pistons would actually be advantageous compared to a forged piston. Basically, is the extra $600 actually worth it?
Old May 8, 2002 | 03:16 PM
Reid's Avatar
Global Moderator
Default Re: forged pistons vs. cast pistons (743teg)
Stock cast pistons have weak ringlands. Also why not sand off the rough edges and coat your forged pistons?
EDIT: Do you do track events or drag race? If just drag, I'd go with cast. If you road race and your engine has to put up with sustained heat I'd do forged. Either way forged pistons are just extra insurance and I believe in doing things once, the right way.
[Modified by Reid, 2:18 PM 5/8/2002]
Old May 8, 2002 | 04:31 PM
ITRbroham's Avatar
shit post warrior
Default Re: forged pistons vs. cast pistons (Reid)
Forged pistons stand up much better to heat and stress.
Old May 8, 2002 | 05:36 PM
RagingAngel's Avatar
Default Re: forged pistons vs. cast pistons (ITRbroham)
Anybody consider that forged pistons don't seem to seal very well?
I'm just asking this as a general question.... I have forgotten if high silicone content is what you would be looking at for a moderately tuned "street car"
and low or zero(?) silicone for max durability and less expansion for the ***** to the wall race cars.....
I suppose rings also play a pretty big role in all of this?
Old May 8, 2002 | 05:45 PM
Gansan's Avatar
Default Re: forged pistons vs. cast pistons (RagingAngel)
Just to be clear, don't you mean silicon? Silicon added to aluminum makes an alloy that is stronger than plain aluminum.
<edit>I was mistaken. Silicon added to aluminum lowers the melting point but also makes it more wear resistant. Hence its application to pistons.</edit>
Silicone is the stuff in breast implants and rubber treatment.
[Modified by Gansan, 9:23 PM 5/8/2002]
Old May 8, 2002 | 06:35 PM
Default Re: forged pistons vs. cast pistons (Gansan)
GAHhhhhhh.... didn't proof read my post.... let it be known.....I'm a breast beast.....
Old May 8, 2002 | 07:03 PM
MugenDC2R's Avatar
One thing to add here, a few aftermarket pistons have redesigned oil drainage. This is good for high rpms because as the B18C oil jets spray oil up at the bottom the piston to cool it down, the oil increases the pistons weight. I know that TODA has redesigned oil drainage so the weight of the pistons don't increase at high rpms.
Old May 8, 2002 | 07:25 PM
sgT's Avatar
sgT
Default Re: forged pistons vs. cast pistons (MugenDC2R)
First of all, silicone content doesnt apply to strength.
Silicone content will determine expansion rates. Low silicone content will
be stronger but will expand more under heat. This makes them louder
when they are cold.
As far as oil drainage goes, the oil jet thing is irrelevant.
Oil control is for sweeping the oil off of the walls as the piston moves.
Not to drain as the oil is sprayed onto them.
And forged pistons dont seal as well??
Old May 8, 2002 | 07:37 PM
Default Re: forged pistons vs. cast pistons (sgT)
Well Steve thanks for clearing that up....
I was curious and merely asked based on some motors I have seen which consumed more oil and just happened to use forged pistons....
Now I call your next step and the people I knew probably didn't build their motors correctly.... they probably didn't.... but an inquiring mind had to know....
here's a hammer for you too.....
Old May 8, 2002 | 07:38 PM
Michael Delaney's Avatar
silicone is for breast implants
silicon is derived from sand and added to alloys to limit heat expansion as Stephen stated....and too much of it actually causes the piston to be more brittle (less detonation resistant).
ITR pistons are forged according to Fumiyasu Suga, Type R's assistant chief engineer ( http://integra.vtec.net/carboy.html) but has higher silicon content than the aftermarket pistons. Everyone seems to be eager to jump on the low silicon content forged piston bandwagon like Ross pistons or Arias pistons and put up with the diesel engine-like rattling on cold starts from loose piston to wall clearances....
Cast pistons are wicked brittle...
[Modified by Michael Delaney, 11:44 PM 5/8/2002]
Old May 8, 2002 | 07:39 PM
when they are cold.
looks like he's a breast beast too then....?
Old May 8, 2002 | 07:42 PM
sgT's Avatar
sgT
Low silicone for FI since temps are hotter, and high for NA genrally
I like real ones myself... no silicone for me.
Old Oct 17, 2002 | 03:35 PM
Big Phat R's Avatar
Default Re: forged pistons vs. cast pistons (743)
Forged pistons are also way lighter than cast ones - which will reduce the mass of the rotating assembly - especially if one uses forged rods as well. This improves the speed at which the motor can rev, and allows the engine to rev higher more safely (assuming it is all balanced properly).
Old Oct 23, 2002 | 06:59 PM
teg92's Avatar
So whats the verdict. Are ITR and CTR pistons actually forged or not? They sure look the same as all other B-series pistons from the underside.
kingofbattle909
May 3, 2011 07:33 AM
crazyguy
Nov 18, 2007 05:08 AM
Ray
Nov 10, 2001 12:02 AM
