Will these wheels fit my EK?
I'm not very competent when it comes to wheel sizes but I was wondering if this offset would work for my car? I own a 96 EK hatch so if anyone can help me that would be great thanks
The specs:
4Hx100 16x7 +34
The specs:
4Hx100 16x7 +34
for an EK assuming a stock wheel is +45 and 15x6 the 16x7 +34 you'll have about 2mm less clearance between the shock and the inside edge of the wheel, and the outside edge will stick further out by about 24mm. depends how low you plan to go you might encounter rubbing, im pretty sure someone here has tried that set up and will tell you if you need spacers or not.
I'm just looking to drop it so theres no wheel gap. Not slamming it or anything. If anyone who has a similar size wheel could let me know that'd be great.
anstitute
Aug 21, 2010 12:02 PM
