my heat sucks any suggestions
Old Nov 19, 2006 | 12:51 PM
theemaddhatterr's Avatar
Default my heat sucks any suggestions
Well as must of you have noticed its getting colder here on the east coast and my heat sucks its luke warm at best. anyone have any ideas of how to make it warmer. I unhooked my fans last week hopeing the car might run a little warmer but it did nothing the car does not run any hotter. any one have any ideas?
Old Nov 19, 2006 | 01:09 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: my heat sucks any suggestions (theemaddhatterr)
Get your system flushed, filled and bled and change the thermostat while you're at it.
Old Nov 19, 2006 | 02:54 PM
GoFastTshirts.com's Avatar
hmm im having the opposite problem trying to get my car to run cooler, goodluck
Old Nov 19, 2006 | 03:07 PM
dwerpk's Avatar
my car took forever to warm up and i just put a stat in
Old Nov 19, 2006 | 03:41 PM
Crx Jimmy's Avatar
get a different thermostat for winter, honda thermos are 171 degrees but you can get 180 and 195 degree thermos at the parts store, also you can change the rad cap to one of a different pressure
Old Nov 19, 2006 | 03:46 PM
Maldito X's Avatar
I thought this was about the heater....guess it's about engine temps
Old Nov 20, 2006 | 08:10 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (sLcREX)
It's about getting the proper temperature coolant through your heater core inside the cabin. If your heat blows lukewarm, either not enough coolant is getting to the core (air bubble or blockage) or it's not being warmed to the proper temp (chenge thermostat).
Old Nov 20, 2006 | 08:36 AM
thesmogman's Avatar
Default Re: (wiZCo)
Yes the T-stat. Mine was stuck open and I had very little heat in the cabin. I had the t-stat changed and now the heater works perfect and my car warms up faster.
Old Nov 20, 2006 | 09:47 AM
crawfo661's Avatar
flush coolant to get out air or blockage, replace thermostat, and fill to proper level with coolant
dclub01
Jan 25, 2017 10:00 PM
irideslammed5021
Aug 29, 2006 07:47 AM
Muckman
Dec 6, 2005 08:14 AM
Ludester
Jan 16, 2004 11:19 AM
