Honda S2000 Honda S2000
B18C5 oil filter compatible w/ F22?
Old Nov 19, 2006 | 12:35 PM
ProjektR's Avatar
Default B18C5 oil filter compatible w/ F22?
Traded in my ITR for a AP2. Now I got a bunch of filters unused filters from Acura that I bought w/ a deal they had at the time. Any ill effects of using the ITR filter oil filter? I've heard of ITR users using S2K filters... just wondering if any ill effects if it's reveresed. Thanks
Old Nov 19, 2006 | 02:01 PM
marcfrank's Avatar
Default Re: B18C5 oil filter compatible w/ F22? (ProjektR)
I have the same problem. just got an 07 s2k and i've got a couple dozen small Hamp filters laying around.
Old Nov 19, 2006 | 06:12 PM
Mike_C's Avatar
there has to be a reason that they're different part numbers... i wouldn't do it.
Old Nov 19, 2006 | 07:05 PM
llxzxll's Avatar
i think they are different part numbers now b/c all of the integras/civics have changed to the new smaller oil filter while the s2000 is still using the same filter they've been using for the past 6 years. they were using the same filter up until that point a couple years ago i believe. i used to use s2000 filters on my b18c5 all the time just b/c i liked to use the older filter.
Old Nov 19, 2006 | 07:07 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektR &raquo;</TD></TR><TR><TD CLASS="quote">Traded in my ITR for a AP2. Now I got a bunch of filters unused filters from Acura that I bought w/ a deal they had at the time. Any ill effects of using the ITR filter oil filter? I've heard of ITR users using S2K filters... just wondering if any ill effects if it's reveresed. Thanks </TD></TR></TABLE>
You'll be fine as long as the thread pitch is the same and the gasket diameter is the same as stock (wouldn't surprise me if it was any different). As far as size is concerned, a larger filter will have more filtration surface area which is an advantage and shouldn't affect oil pressure with a slight increase in oil capacity.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">there has to be a reason that they're different part numbers... i wouldn't do it.</TD></TR></TABLE>
The RC51 uses the same oil filter as the Insight (different part number) at a $7 discount. I got sick of paying $16 for a oil filter for my bike.
Old Nov 19, 2006 | 10:19 PM
s2kdre's Avatar
Default Re: B18C5 oil filter compatible w/ F22? (evil vapor)
the thread pitch has been the same on all hondas since 87-present, its just when the 01 civic came out they changed the size thats all.
Old Nov 20, 2006 | 04:16 AM
cmdr430's Avatar
iirc guys are using the s2k filter on their r's...... so, i do not know why the r filter would not work on the s2k.....
Old Nov 21, 2006 | 06:20 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
Default Re: B18C5 oil filter compatible w/ F22? (cmdr430)
i thought the s2k toyo roki oil filter was like the best honda oil filter? reason being why everyone interchanges them on thier honda's. well i guess a few times with the itr filter won't hurt.
Old Nov 23, 2006 | 05:37 AM
PogKai's Avatar
I work at Honda dealer, we use the same filter in all honda models, no problems. it's the small one.
Old Nov 23, 2006 | 07:56 AM
blkturbos2k's Avatar
Default Re: (PogKai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PogKai &raquo;</TD></TR><TR><TD CLASS="quote">I work at Honda dealer, we use the same filter in all honda models, no problems. it's the small one.</TD></TR></TABLE>
I also worked at Honda, If you are using a 15400-plm-a02 you are putting on the wrong filter. The PLM-A02 filter will fit but is much smaller. Also the oil flow is not as good. I have used the smaller oil filter but that is not what Honda calls for.
Also, most of the parts dept dont know what type of oil to use in the rear diff. They will put VTM-4 in your diff
HyphyBB6
Oct 21, 2008 09:40 PM
jinu
Jan 13, 2008 10:54 AM
rohec04
Aug 7, 2007 10:11 AM
HamiltonRex
Oct 10, 2004 07:00 PM
TypeRuz
Aug 4, 2004 04:46 PM
