where did you place your aftermarket XM antenna and unit?
I did mine on the front but i dont have any pics
al i did was place the antenna in the middle and run the wire under the gasket for the front windsheild theres like a 3 mm space between the glass and the roof of the car under ther and i ran it down to the drivers side door to the joint for the pillar and the drivers side fender than brought it in to my reciever
I have my antenna sitting just beside the tweeter on the right hand side of the dash. I ran the wire through the tweeter grill, behind the glove box to the center console where the power and aux plugs are.
*EDIT* here are the pics
Modified by Zesti1 at 1:48 PM 12/2/2006
here is my setup:
as for location of antenna, i located mine right in the little rain gutter right above the driver door, i ran the wire down the gasket down the side of the windshield, then under the hood, there is a small hole going through to the door jam i attached the antenna wire to a wire hanger and poked it through then zip tied it up under the dash, into the console then up infront of the shifter and to the unit.
hope that helps. looks and works great.
f22a
Jun 11, 2012 06:59 PM
specoperformance
Sep 16, 2008 01:28 PM
SQ Kuk
Audio / Security / Video
21
May 19, 2006 03:12 PM
aftermarket, antenna, connecting, fit, honda, location, oem, place, recommendations, retro, s2000, satellite, sirius, windshield, xm
