JDM ITR Tranny 4.78. PROBLEMS with 4th gear.
Old Nov 19, 2006 | 11:13 AM
ChameleonDesignz's Avatar
Default JDM ITR Tranny 4.78. PROBLEMS with 4th gear.
I have a 98 jdm itr tranny with problems on 4th gear. At high speed it wont shift (sometimes it does) It all started one day...after making my LS >VTEC i started having problems with 3th gear not shifting at hifh speed (8800 - 9400rpms).
Some days later i found the slave cylinder haging by just one bolt! so we figure out it was that the problem...
It worked fine... and after another day at the track it started randomly doin it.
But it worked, now i made my car b20-vtec (216whp) and it started again worst.
It doesnt make any noise, no grinding, it feels just like when the slave cylinder was not applying whole pressure, since it was hagingg w just one bolt. I use ACT street Presure plate w/ exedy OEM disc.
We replaced whole clutch master cylinder + slave, new fluid, OEM tranny oil, act flywheel, etc...
i daily drive the car, It works fine; it just doesnt shift after around 8500rpm
ANY HELP??? Someone with same problem...
Modified by ChameleonDesignz at 8:06 AM 11/20/2006
Old Nov 19, 2006 | 10:35 PM
trickedvtec's Avatar
mine does this with 3 gear at high rpms. i have b16 tranny
Old Nov 20, 2006 | 03:04 AM
Default Re: (trickedvtec)
yes same here, that was i meant sorry!
from 3rd to 4th at more than 8500 is shifting, sometime it does...
Old Nov 20, 2006 | 07:05 AM
anyone?
Old Nov 20, 2006 | 09:34 PM
no one knows a posible cause or solution!?
allmotorgsr98
Transmission & Drivetrain
12
Jun 5, 2011 10:25 PM
ChameleonDesignz
Nov 19, 2006 11:12 AM
ITR RACER
Aug 10, 2003 08:01 AM
lopey
May 20, 2003 05:19 PM
Kev95lx
Oct 1, 2002 07:52 AM
