Suspension & Brakes Theory, alignment, spring rates....
lowering my EK
Old Nov 19, 2006 | 10:29 AM
IAcivicEK's Avatar
Banned
Default lowering my EK
what would be the best route to go about lowering my 97 civic coupe? Im not wanting to spend a butt-load of money. so, something cheap, yet cost effective. It will have purpose, not just for looks, if that helps any. thanks
Old Nov 19, 2006 | 10:34 AM
BlueIntegraBoy's Avatar
Default Re: lowering my EK (IAcivicEK)
It depends on your situation. If you plan to use it for cruising with little to no fun, I would suggest in lowering springs and some struts. However, if you want height adjustability, there are sleeved coilovers (with appropriate struts) that will suit your needs. Price varies on sleeved coilovers depending on brand. Now, if you are talking about full coilovers, they are slightly pricier, but some offer more adjustability.
People are going to recommend Ground Control (with custom spring rates to suit your needs) coilovers with Koni yellow struts.
Old Nov 20, 2006 | 01:14 PM
ninja 6's Avatar
Default Re: lowering my EK (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
People are going to recommend Ground Control (with custom spring rates to suit your needs) coilovers with Koni yellow struts.</TD></TR></TABLE>
A cheaper alternative to Koni yellows are KYB AGX struts, which work perfectly fine on a low drop. However, I also recommend Ground Control adjustable height springs
Old Dec 1, 2006 | 11:42 AM
gabebauman's Avatar
Default Re: lowering my EK (ucd)
OTS GC coilovers and KYB AGX setup rides good.
Old Dec 2, 2006 | 06:39 AM
JDMFreak's Avatar
Default Re: lowering my EK (gabebauman)
^^^^ that look sexy
ek25
Dec 3, 2008 11:46 AM
FRKWOO
13
Aug 11, 2008 03:36 PM
sohcvtec97
Sep 26, 2005 10:37 PM
Paprika
May 31, 2005 08:12 AM
1loudex
35
Jan 6, 2004 03:55 PM
