HELP NEEDED! Motor Swap radiator question ****
Old Nov 19, 2006 | 08:34 AM
gentek1145's Avatar
Default HELP NEEDED! Motor Swap radiator question ****
Ok, so heres the problem.
We just finished a b16a motor swap in a del sol. The stock radiator from the del sol is too small on the inlet/outlet. THe B-series hoses are just a little too big.
correct me if im wrong, but isnt the stock del sol rad. a 1 1/8" inlet/outlet
and the b-series motor (civic si 00) is a 1 1/4" inlet/outlet?
if so, then will this solve my problem?:
92-00 Civic (ALL),93-97 Del Sol $159.00 SHIPPED!
Quick Facts:
• 100% High-Quality Light Weight Aluminum
• Billet Aluminum Fill Neck
• 1.1 Rated Radiator Cap
• 100% OEM fit on 1992-1995 Honda Civic Manualincluding fan mounts
• 20-25% Increase in Cooling Ability
• Core Size: 14.5" W x 2" D x 13.75" H
• Full Size: 14.5" W x 2" D x 17.5" H
• Inlet/Outlet Size: 1.25"
won't this basically be a drop-in exchange of the oem one, and allow me to re-use the B-series hoses without any modification?????
THanks for any help at all!!!!!
Old Nov 19, 2006 | 09:02 AM
JDMFreak's Avatar
Default Re: HELP NEEDED! Motor Swap radiator question **** (gentek1145)
it funny how you word it one forum like this and on another forum like something else...
you can use a SOHC rad, all you need to do is get LS hoses, and the bottom should fit fine and the top one you will have to add a little(be creative) of hose on the inside, if you know what i mean ( ( ) ) kinda like this effect.
i hope this help. trying to save your buddy or yourself some money... it work for me
o yes, to be exact on the hose, just take it up to autozone and have them match the linings
Old Nov 19, 2006 | 09:14 AM
gentek1145's Avatar
thankyou. Whats the size on the LS hose for the lower one?Is it 1.25" on teh lower?
Old Nov 19, 2006 | 11:47 AM
spoonracer84eg's Avatar
Default Re: (gentek1145)
Try password.jdm for the hoses if you want nice onces. I believe they were samco.
raverx3m
May 19, 2011 10:54 AM
usmarinedelta
Oct 2, 2007 05:40 AM
BDaTurboTeg
Jul 8, 2005 11:16 PM
phantom_sol
10
Apr 28, 2003 05:53 PM
x James Bond x
Apr 16, 2003 03:14 PM
