DIY polish/paint valvecover
Old May 8, 2002 | 02:35 PM
speeddave's Avatar
Default DIY polish/paint valvecover
i am looking for someone who has polished their stock valvecover themselves, or if anybody has done it and wished they just painted it. just kinda looking for the grits/stripper you used, etc... any info at all would be cool. thanks(i posted in appearance forum, but nothing)
Old May 8, 2002 | 02:46 PM
speedlimitR's Avatar
Default Re: DIY polish/paint valvecover (speeddave)
i helped my friend do his 92dx motor back when he had that.
it was not hard, just a lot of work. well time. but it was not to bad
if you liek that look, go for it...
Old May 8, 2002 | 02:50 PM
therealciviczc's Avatar
Its easy on the D16.
I did it by hand the first time, then a second time with a sander. The sander is obviously easier, but I still did the last few steps by hand.
I started with 80 grit. This is the most important part of the process. Get the cover down to all good aluminum. Your first step determines what it will look like in the end. After the first step, you're just sanding the sand marks out of the cover from the previous step until its smooth. Get 3m sand paper, or something good.
I went...
80
100
150
320
400
600
1200
Then I used MAAS polish. The polish makes the shine. Get MAAS if you can. I've never personally used anything near as good as MAAS!
Good luck.
Old May 8, 2002 | 04:13 PM
speeddave's Avatar
Default Re: DIY polish/paint valvecover (therealciviczc)
sweet thanks, i couldn't have got a better reply! where would i get maas polish? home depot? crappy tire?
Old May 9, 2002 | 04:13 AM
I'm not sure where to get it. I get it at Meijer Food Stores. It's tough to find, but honestly I've tried about 10 different polishes, and none of them work even close to as well as MAAS. (I could be spelling it wrong).
Old May 9, 2002 | 04:25 AM
slowpokesi's Avatar
or you could use wenol.
personally i used mothers
i dont know if i would start out with 80, your scratches will be too deep i would start out around 300
it doesnt look that good, but i had been working on the car and those spots are finger prints
Old May 9, 2002 | 05:25 AM
JurakS's Avatar
mm..i don' know what you guys are talking about..but i would like to polish my valve cover too..what do you guys mean by grit? and what are the steps in doing so? thanks!
Old May 9, 2002 | 05:31 AM
MiraiZ's Avatar
Default Re: DIY polish/paint valvecover (Juraks)
grit=courseness of the sandpaper
on the back of the sandpaper there is usually a number that tells the grit of the paper...the higher the number the more finer the grit.....finer grit is used to smooth smaller imperfections
Old May 9, 2002 | 05:37 AM
SuperCivic's Avatar
so what did you guys use to get the old flakey paint off evenly? i've gotta do mine too. how do you think it would look with just stripped off paint..not polished or anything?
Old May 9, 2002 | 05:56 AM
slowpokesi's Avatar
Default Re: DIY polish/paint valvecover (SuperCivic)
AIRCRAFT PAINT STRIPPER,
GET some rubber gloves, and start applying it to the valve cover, waith 30 seconds and the stuff rubbs off.
Old May 9, 2002 | 06:08 AM
speeddave's Avatar
well, i stripped my cover last night, the cover w/o the paint looks good, dull aluminum finish. thought about leaving it that color cause i didn't mind it, but had bought all the sandpaper so... anyway i started w/80 grit, it is kinda rough but the scratches work out... after a while, hehe. i ended up buying autosol polish, couldn't find maas. so we'll see. so far so good, thanks for the help guys!
Old May 9, 2002 | 06:19 AM
SuperCivic's Avatar
i'm gonna be different and NOT polish it. it'll look like crap, and match the rest of my car
Old May 9, 2002 | 08:31 AM
88civic's Avatar
how about this one, this car is super nice and is one of the best cars i have seen that is show and daily dirven..
[Modified by 88civic, 9:32 AM 5/9/2002]
Old May 9, 2002 | 10:16 AM
SuperCivic's Avatar
Default Re: DIY polish/paint valvecover (slowpokesi)
ok, i just bought me a big ol can of aircraft stripper. got some more detailed instructions?
Old May 9, 2002 | 12:38 PM
Giuseppe's Avatar
put that shiat on, let it soak into the black paint.
clean the valve cover off...easy as pie.!
Old May 9, 2002 | 12:41 PM
carsaregood's Avatar
Default Re: DIY polish/paint valvecover (Giuseppe)
yeah, to get the old paint off, i used this stuff called Dad's spray or soemthing like that. I got it from Sears for less than 10 bucks. Its this gooey stuff you spray on, and after about 15 minutes, the paint bubbles up, and you just wipe it off, and all the paint comes with it. I tried sanding the paint off, but that was so much harder than doing this. just be careful, this stuff is pretty savage, it'll hurt if you touch it, don't ask how i know...
[Modified by carsaregood, 9:42 PM 5/9/2002]
Old May 10, 2002 | 03:58 AM
SuperCivic's Avatar
ok, i got MOST of the paint off the valve cover..there's still a little i couldn't get, and there's some dark spots in the aluminum. should i go ahead with the sandpaper now, or keep stripping? i hit it with stripper 3 times.
Old May 10, 2002 | 06:21 AM
speeddave's Avatar
same thing w/my valvecover, it had some real dark spots by the oil filler hole and the timing chain cover. i just sanded them out w/80 grit then continued w/120 etc...
Old May 10, 2002 | 07:02 AM
The above is something to thing about. I started with 80 because my valve cover was 10 years old at the time and that aluminum had some real dark spots and rough spots. You'll be able to get the scratches out, but you may be able to save time starting higher if your vavle cover is already in good shape. Personnally I think that if you start with 300 you'll still be able to see dark spots, but it really depends on what you're starting with.
I can't say it enough about the MAAS. I tried so many different polishes (Mothers, 3m, etc) and the MAAS was miles above the rest. Going over it twice with MAAS turned it from looking like something I had done to something almost professional looking in a matter of minutes.
Old May 10, 2002 | 11:28 AM
SuperCivic's Avatar
ok, got me some sandpaper and some maas. i'll post pics of the progress
btw, how do you get to the really small spots like betwee the letters?
Old May 10, 2002 | 11:46 AM
ImportHatch's Avatar
I polished mine myself but I dont have a pic of it....
Yager-
Old May 10, 2002 | 11:51 AM
Zer0DazE's Avatar
where are you getting 1200 from? i can't find that stuff anywhere
thanks
Old May 10, 2002 | 12:16 PM
slowpokesi's Avatar
Default Re: DIY polish/paint valvecover (Zer0DazE)
home depot or autozone
Old May 10, 2002 | 12:41 PM
Zer0DazE's Avatar
homedepot didnt have it
Old May 10, 2002 | 12:57 PM
speeddave's Avatar
i couldn't find 1200 either so i just went w/1500, i am also curious as to how to get the small parts between the letters, and where you found the maas polish????
