nitto 555r drag radials
Old Nov 19, 2006 | 05:46 AM
dragaholic's Avatar
Default nitto 555r drag radials
Hi guys,
What pressure would you guys run on these at the track. Can it be lowered to around 10 psi or lower?
Old Nov 19, 2006 | 02:50 PM
b18c195's Avatar
Default Re: nitto 555r drag radials (dragaholic)
i havent used the nittos but the bfgs ive lowered it to like 9 psi... i think same thing
Old Nov 19, 2006 | 02:57 PM
nsxmatt's Avatar
It's a radial tire with a stiff sidewall, lowering it to 10psi is pointless since the only part pushing on the ground will be the outer edges. You want enough air in the tire to allow the whole tire to have a contact patch. Start at 20lbs and slowly work your way down but don't go past 15-12psi on the nittos.
accord99power
May 27, 2009 03:17 PM
crazy_ls_90
Aug 25, 2008 04:50 PM
Nextelbuddy
Apr 13, 2004 01:03 PM
itr501
Jun 11, 2002 12:54 PM
01PYTypeR#1140
May 16, 2002 07:33 AM
