DIY Tranny change
Hey everyone,
i decide to save some money and do my own tranny fluid change just wondering if anyone has tips on properly doin a tranny fluid change? much appreciated
91 honda accond lx ...320km
Go to the dealer and get 3 quarts of honda Z-1 ATF; then remove the drain plug with your 3/8" breaker bar, clean all of the second gear clutch pak off the magnet of the plug. Then reinstall the drain plug using the crush washer; next pour the 3 quarts into the dip stick hole with a long funnel. Taa Daaa all done.
The trans is supposed to take 2.8 quarts, but the extra .2 of a quart won't hurt anything.
Or if its 5 Speed, Get 3 quarts of 75w140 Mobil Gear Oil, pull the drain plug on the bottom, then fill it back up with the fill plug on the front of the tranny,
Fill it up Until its comming out of the fill hole, then let it drain out of the fill hole until its a slow drip..
Or if u wanna give your trany a little help put in 1 Lucas Transmission fix and the rest with the gear oil
northkai3
26
Sep 29, 2013 11:53 AM
JASIYAH6
Mar 9, 2009 10:05 AM
