Is 10 to 11 A/F ratio too conservative???
I know that the optimal ratio should be around 12 or so,,, but want to know if that is alright running 10 to 11 ratio....
LS-T running 7 psi
what about adding 2 lb of boost to it?
your input is appreciated
LS-T running 7 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alghafat424 »</TD></TR><TR><TD CLASS="quote">I know that the optimal ratio should be around 12 or so,,, but want to know if that is alright running 10 to 11 ratio....
LS-T running 7 psi
your input is appreciated</TD></TR></TABLE>
Guessing the setup is on a stock motor, using 91-93 oct unleaded fuel on a 9.0:1 compression cast piston setup with a general t3/t4 setup. A good a/f ratio target would be 11.0:1-11.9:1
Good luck.
LS-T running 7 psi
Good luck.
fueling isn't as important as timing. the fuel should be left at 12.0. the reason why people go richer is because it burns slower thus in a way "retarding" the timing. Fueling also doesn't have the cooling effect people think it does. 12.0 AFR is suggested because EGT's are kept to a minimum. N/A cars can run 13.0 (the most power) because their intake charges are less dense AND cooler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxhatched »</TD></TR><TR><TD CLASS="quote">12.0 is to lean for pump gas -11.5 and the degrees of timing determine all the factors of speed or longevity. It depends on how long you want to last .</TD></TR></TABLE>
Yea great reply.
12.0:1 is just fine... especially for 7psi. 10-11:1 is rediculously rich.
Yea great reply.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">fuel richer is because it burns slower thus in a way "retarding" the timing. .</TD></TR></TABLE>
Haha.. I got tuned on 93, octane. I noticed when i put 91 in the car (93 not avail) that the car went a few mph faster.. lol.
how about if my fuel is 96 octane, Am I still supposed to retard the timing?
If yes, How many degrees per lb? is it still .75/lb??
thanks a lot
thanks a lot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alghafat424 »</TD></TR><TR><TD CLASS="quote">how about if my fuel is 96 octane, Am I still supposed to retard the timing?
thanks a lot</TD></TR></TABLE>
put it on a dyno and find out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">
There is no dyno close to me now
I want to street tune it
in in the low 12s at wot, aroudn 12.1-12.3. im on 7psi gsr motor, is that a problem. runs fine. when tuned, he said he really didnt have to adjust the timing. very reputable tuner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame »</TD></TR><TR><TD CLASS="quote">in in the low 12s at wot, aroudn 12.1-12.3. im on 7psi gsr motor, is that a problem. runs fine. when tuned, he said he really didnt have to adjust the timing. very reputable tuner</TD></TR></TABLE>
How did he not have to adjust timing? Stock ECUs don't even have timing values for positive manifold pressure. If you mean he didn't have to adjust the values over the basemap he set, then that's understandable.
You would be ok to lean it out a bit, 12:1 is a good mixture to shoot for at that psi, I'm 12.3ish falling to 11.4 at top RPMs.
The street is not really the place to tune timing, you won't be able to see the effects of your changes.
im sorry, he said he didnt have to make physical sdjustments lie messing with the distributor. he did a little sumtin sumtin on hondata. but not positive what was done. he got 238whp out of it on a conservative tune. i just want it to be safe and reliable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alghafat424 »</TD></TR><TR><TD CLASS="quote">There is no dyno close to me now
I want to street tune it</TD></TR></TABLE>
in that case then your screwed
On 7psi? I'm thinking 12.5 is perfect. Maybe 11:* on 20psi+
For all the motors I've tuned, I find gonig from 10:1 - 11:1 A/F is alot bigger gains then going from 11:1 - 12:1. Fine line between way over fueling the motor. I always try to tune for 11-11.5:1 regardless of psi.
where my o2 bung is for my wideband, there is a little leak that isnt fully welded. by how much will that throw off my wideband? because im thinkin at wot, the exhuast is coming at such a rapid rate, it wouldnt matter, or am i just wrong?
10's is a little too rich. i think for that boost level 11.8-12.2 is fine. ( ive personally run motors on 13+ a/f at 10 psi by accident and never had a problem, timing was nice and conservative).
just set the a/f to like 12:1 and then spend the time tuning timing. you really need a dyno for it, but since you dont have one, i guess do a plug check rather often. with a gsr you should probably be around 22* up top at around 8-9 psi, for an ls maybe a little less, like 20* for 9 psi
can someone please make a comment on TIP IN. My a/f dips to ~11.4 when I floor it and quickly goes to high 11s as I rev out the motor, is that ok? Seems to be making better than average power (119mph @ 2300lbs = ~300whp) @22deg TT @ 8psi. and the plugs look good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">
just set the a/f to like 12:1 and then spend the time tuning timing. you really need a dyno for it, but since you dont have one, i guess do a plug check rather often. with a gsr you should probably be around 22* up top at around 8-9 psi, for an ls maybe a little less, like 20* for 9 psi</TD></TR></TABLE>
But, is it OK that if I'm @ 10 psi or lower, I don't need to mess with timimg
I heard this from a tuner that says there is no harm if < 10 psi
Modified by alghafat424 at 1:49 AM 11/20/2006
