I NEED HELP MY CAR IS BOGGING!!!!!!!!
Hey HT-ers, I recently changed my throttle body and am experiencing delayed throttle to engine response and power bog at certain RPMs dependent on gear I’m in, almost as if the ECU cuts fuel once it hits a certain RPM. I checked the MAP sensor which was fine but the TPS sensor is not reading anywhere to proper voltage. Could a bad TPS sensor cause all these problems? Any suggestions others things to look for or what to do?
Just wanted to vouch for this guy.
His car is really broken. Someone please help this man. TPS was reading 2V with throttle closed. I read that it should be .5V closed and 4.8 open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">I bet you have the MAP sensor plug on the TPS sensor and vise versa.</TD></TR></TABLE>
Nope, we double check that and even tried with the MAP and TPS sensor vise versa
GSR-T-
Nov 13, 2003 07:54 AM
comptechgsr2000
May 8, 2002 03:53 PM
