Air/Fuel ratio question
Old Nov 18, 2006 | 09:51 PM
NA JDM GSR's Avatar
Default Air/Fuel ratio question
im anoob at this and i was wondering how u adjust your A/F??...do u have to by sumthing
Old Nov 18, 2006 | 10:14 PM
Duane_in_Japan's Avatar
Default Re: Air/Fuel ratio question (NA JDM GSR)
Yes, keep clean oil in it, it gets gas past the rings and the PCV system reburns those rich oil fumes. Keep the throttlebody clean, take it off and clean it really good, new gasket to put it back on. Keep the coolant full and changed every couple of years, keep the air out so the idle controller works properly as it is warming up. Have the O2 sensor scoped for proper activity, a lazy O2 (A/F sensor) will mess things up and keep it tuned up to properly burn your proper AF ratio.
With proper sensors the computer regulates the AF ratio all by itself.
Old Nov 18, 2006 | 10:17 PM
NA JDM GSR's Avatar
Default Re: Air/Fuel ratio question (Duane_in_Japan)
if i buy a A/F gauge, where do i connect it to??
Old Nov 18, 2006 | 10:41 PM
NA JDM GSR's Avatar
Default Re: Air/Fuel ratio question (Shepherd2)
get out of here noob
6 posts!! is that a joke??
Old Nov 19, 2006 | 04:58 AM
You need a wideband O2 sensor and your viewscreen to view it, some laptop software would be better but everything is up to your budget.
Old Nov 19, 2006 | 11:12 AM
NA JDM GSR's Avatar
wuts a good wideband o2 sensor to get
Old Nov 19, 2006 | 11:23 AM
mmuller's Avatar
Mad Scientist
on my opinion zeitronix takes the price; cheap, it comes with datalogging software and egt input. It also now comes with a linear wideband output.
Old Nov 19, 2006 | 02:42 PM
B e v - T e c h I n c.'s Avatar
ok be nice to the NOOB... Yes you can buy something such as an Apexi VAFC or SAFC, or some other form of an Air/Fuel Controller. It's not really very necessary on a stock application, but it can help with some mods. hope the helps..
kraaaaap
Nov 21, 2007 07:35 PM
almostboostedgsr
Jul 1, 2007 04:01 AM
Rocket
20
Jun 1, 2005 02:15 PM
acatak
Apr 14, 2003 08:16 AM
CalvitoSol
Jun 7, 2002 10:44 AM
