ITR coilovers in a gsr
Old Nov 18, 2006 | 08:42 PM
Formula1's Avatar
Default ITR coilovers in a gsr
Hi,
I have a 2000 gsr and I was hoping to upgrade my suspension to some stuff higher up the tein ladder (currently have super street stuff, but after a nice day going up and down a mountain, I think I want to take my suspension even further, though it was already amazing I thought) It seems that the super racing and type flex coilovers are only available for the type r, which I only really know has different rear lca's. So I'm wondering if all I need is the rear lca's from a type r or if there's something else.
Also, how valuable do you think independent compression and rebound adjustment is? Both for a daily driver that sees some scca events and for a more dedicated track car.
Old Nov 18, 2006 | 09:27 PM
blackdelslo's Avatar
Default Re: ITR coilovers in a gsr (Formula1)
They make flex's for the gsr. Spring rates will be a big factor on ride quality and i think the flex's will be a good upgrade from the SS. Many may tell you koni/ground control because it is cheaper. The tein brand may be a bit pricey but they do have some nice stuff out there. If your going to do it, do it right the first time.
Old Nov 18, 2006 | 09:33 PM
Formula1's Avatar
thanks for the info. I was mostly asking about the super racing setup for information, I doubt I'll ever shell out that kind of money (or take on building a full-fledged road race car). I'll do some more research about other options (I heard a lot of the koni/ground control arguments when I first bought my suspension)
Old Nov 18, 2006 | 10:27 PM
bg-33p's Avatar
Default Re: (Formula1)
Yes, you will need to change rear lca's only if you are to get a setup suspension designed for an itr.
Old Nov 22, 2006 | 10:18 AM
VTECth1s's Avatar
Default Re: (teggysue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you will need to change rear lca's only if you are to get a setup suspension designed for an itr.</TD></TR></TABLE>
agreed
Old Nov 22, 2006 | 11:36 AM
motoman's Avatar
You might also want to have a sawzall handy for those lca bolts.
Old Nov 22, 2006 | 12:03 PM
the_unknown's Avatar
GDD Lonely Krew
my friend has tein RA's on an em1 and that thing is on rails i swear. it takes getting used to though and the ride quality for a dd is horrible!!!
Old Nov 24, 2006 | 01:08 AM
Coked GSR's Avatar
Default Re: ITR coilovers in a gsr (blackdelslo)
i Just helped install the new flex system yesterday on my friends 99 gsr. they fit strait from the box, but i recommend a front and rear camber kit also...actually its a must
Engn
Honda S2000
30
Jan 31, 2005 09:34 PM
GumballNA
Dec 27, 2004 08:10 PM
TurblowR
Dec 7, 2004 10:28 PM
JunIntegra
Jan 15, 2004 10:22 AM
CivicSimon
Jun 18, 2002 07:47 AM
