Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!!
Old May 8, 2002 | 02:14 PM
Integra_Boi's Avatar
New User
Default Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!!
hey guys.. just reput my stuff back on after replacing the intake manifold gasket... when i turn on the car and the fuel pump comes on.. it sprays gas out inbeween the fuel rail and the fuel pressure regulator.. i tighted it and put a O ring washer in there.. its still spraying out the side.. any clue what might cause this?
Old May 8, 2002 | 02:18 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!! (Integra_Boi)
using teflon tape or paste?
Old May 8, 2002 | 02:37 PM
New User
Default Re: Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!! (Pb_Foot)
around what?the sides?
Old May 8, 2002 | 06:32 PM
New User
need sum tips here guys..
Old May 8, 2002 | 11:11 PM
New User
could i possible be putting out too much fuel
Old May 9, 2002 | 12:59 PM
New User
Old May 9, 2002 | 01:41 PM
Doctor CorteZ's Avatar
yeah thats the ONLY cure , teflon tape =
Old May 9, 2002 | 02:38 PM
frogsr's Avatar
i'm thinking either the fpr setting or the o ring rubber washer.
Old May 9, 2002 | 02:39 PM
reefer_bob's Avatar
Default Re: Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!! (frogsr)
There's a tiny o-ring inbetween there that you may have lost. Look to see if it's there, else you might have to buy a new one...
Old May 9, 2002 | 03:09 PM
New User
Default Re: Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!! (reefer_bob)
i bought a faucet O ring washer instead because my local acura dealer needs to special order it. The O ring fits fine.. i'm still stuck on this problem.. could it be too much fuel pressure? if so.. how do i lower/releave it?
Old May 9, 2002 | 04:06 PM
reefer_bob's Avatar
The reguar fawcet oring is designed for water, not fuel. It'll prolly get eaten away... That's just a thought though...
Old May 9, 2002 | 04:10 PM
Mr. Softee's Avatar
missing o ring
Old May 9, 2002 | 07:16 PM
New User
Default Re: Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!! (94goldjungsr)
so you guys still think its the O ring? aright i'm gonna try to put in the order tomorrow or see if NAPA has it in stock. Acura wants 13 bucks for that washer..
Old May 9, 2002 | 07:52 PM
CM-R's Avatar
Mine leaked cause the o ring was cut a little so i replaced it and the problem was gone...make sure the o ring is seated perfectly....
[Modified by CM-R, 8:52 PM 5/9/2002]
Old May 9, 2002 | 08:01 PM
New User
Default Re: Fuelrail/Fuel Regulator gap spraying out fuel... TIPS?!! (CM-R)
such little thing makes a difference =/
Old May 10, 2002 | 07:49 AM
New User
i replaced the O ring with a factory one today and its still spraying out.. i replaced the manifold with skunk2... it doesn't use one hole on the top ... my firend told me to leave that hose out .. its from the big place thing that the fuel filter goes to.. when you look at it.. its on the bottom left.. big black canister looking thing..
Old May 10, 2002 | 07:57 AM
reefer_bob's Avatar
Can ya take a picture, and with an arrow of where the leak is? I guess I"m confused.
Old May 10, 2002 | 12:50 PM
reefer_bob's Avatar
Hmmm... with a new o-ring there, there should be no reason why that's leaking, unless you droped it or something, and created a flaw in the two surfaces... That's really really strange... I guess I'm stumped on this one. Maybe try the Tech forum...
Also, isn't that black resovoir for the GSR manifold, that's the IAB resovoir or something, you should be able to take that out...
Do you have an aftermarket fuel pump which is putting super pressure on your fuel rail maybe? I'm guessing here now....
Old May 10, 2002 | 07:29 PM
New User
hey reefer_bob.. thanks for your help.. finally located the problem.. there is a Hair thin crack in the FPR... so i gotta purchase a new one... any other selections other then AEM?
Old May 10, 2002 | 08:07 PM
New User
AEM
Unless of course you wanna buy my used stock FPR...
Old May 10, 2002 | 08:08 PM
New User
how muc?
Old May 10, 2002 | 08:34 PM
New User
I dunno what it's worth. I'll say... $25 shipped if that sounds fair.
Old May 11, 2002 | 01:55 AM
reefer_bob's Avatar
Sweet, I'm glad you found the problem.... That and the fact that I wasn't smoking too much crack at not figuring out the problem... The AEM unit is nice, but it's a little spendy at like 125 or so... There are a couple options for ya... Good Luck!
Old May 11, 2002 | 10:32 AM
New User
hey pbfoot i'm actually picking up one today before i saw your offer for 25 also.. thanks for your offer though.. i apperciate it... as for that AEM reefer... its 159 retail and the best price i can find is 150 shipped... I think i'm gonna pick up the stock one today and just spend the money elsewhere, which it could do more DAMAGE
QUESTOYZ by RHanDy
Aug 24, 2005 06:52 PM
Bantam
Mar 7, 2003 08:58 AM
digitalspice
Dec 18, 2001 07:57 AM
laughinxxx
Nov 14, 2001 10:25 AM
