Want to install aftermarket seats but retain OEM seat belt buckle...
Old Nov 18, 2006 | 07:16 PM
MestizoRacer310's Avatar
Default Want to install aftermarket seats but retain OEM seat belt buckle...
which are attached to OEM seats. Found a set of Wedge brackets and seats for cheap...want to know how to do this...I want to keep my OEM seat belts and later on MAYBE put in Schroth ASM harnesses. Please keep the posts informative, I don't want clutter, bs, etc. Thanks in advance to those with information I can use..
Old Nov 18, 2006 | 09:54 PM
pos_cd5's Avatar
Default Re: Want to install aftermarket seats but retain OEM seat belt buckle... (MestizoRacer310)
you should post this in the road racing/ autocross forum. you will get better and more informative ansers in there
Old Nov 18, 2006 | 10:14 PM
importfanatic17's Avatar
Can't you just bolt some brackets to the floor or the center console and bolt your seat belt piece to it?
Old Nov 19, 2006 | 04:08 AM
pos_cd5's Avatar
Default Re: Want to install aftermarket seats but retain OEM seat belt buckle... (importfanatic17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfanatic17 &raquo;</TD></TR><TR><TD CLASS="quote">Can't you just bolt some brackets to the floor or the center console and bolt your seat belt piece to it?</TD></TR></TABLE>
theorertically it would work. but the key issue is safety. i personally don't know how safe that option is, but someone in the road racing/auto cross forum might know, since they usually have aftermarket racing seats and harnesses and safety to them is just as, if not more, important then being fast.
Old Nov 19, 2006 | 12:46 PM
standbackimapro's Avatar
That Will Look so stupid, Imagine racing seats, with the stock Seatbelts, it will look rediculous, and youll probably be called a ricer
Old Nov 19, 2006 | 01:18 PM
pos_cd5's Avatar
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">That Will Look so stupid, Imagine racing seats, with the stock Seatbelts, it will look rediculous, and youll probably be called a ricer</TD></TR></TABLE>
alot of people keep the stock seatbelts when they switch to racing seats. strapping on a 4/5 point harness 10 times a day isnt exactly convenient.
Old Nov 19, 2006 | 09:44 PM
Default Re: (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">
alot of people keep the stock seatbelts when they switch to racing seats. strapping on a 4/5 point harness 10 times a day isnt exactly convenient.</TD></TR></TABLE>
very true!!
Old Nov 20, 2006 | 01:29 AM
iam7head's Avatar
you need a harness/roll bar to mount a harness, and you do not want to wear a harness everyday in traffic. if you still can't figure out why..sometime about your neck snapping and your rib cage collapseing (read: search)
it's perfectly fine to use your stock SRS seatbelt with racing seat, just make sure the bracket(please do NOT use oem bracket) is not too low so your face will be in the way of the air bag
Old Nov 20, 2006 | 05:11 AM
Prodigal Son's Avatar
Default Re: Want to install aftermarket seats but retain OEM seat belt buckle... (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackiamapro &raquo;</TD></TR><TR><TD CLASS="quote">
That Will Look so stupid, Imagine racing seats, with the stock Seatbelts, it will look rediculous, and youll probably be called a ricer .</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">Please keep the posts informative, I don't want clutter, bs, etc.</TD></TR></TABLE>
In my old Civic I had both a 4 point harness and the OEM belt. Like someone already said, it's not exactly comfortable to drive around in a harness all the time. On my Civic the belts were attatched to the body and the lap belt was snaked through the slots on the seat right under the harness.
Since one of the belts in seat mounted, you should probably keep it that way as opposed to attaching it to the tunnel. Take the old seat belt mounting piece and try and weld it to the seat bracket. Look for the thickest part of the bracket to weld to.
Old Nov 20, 2006 | 05:19 AM
Default Re: Want to install aftermarket seats but retain OEM seat belt buckle... (Prodigal Son)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
it's perfectly fine to use your stock SRS seatbelt with racing seat, just make sure the bracket(please do NOT use oem bracket) is not too low so your face will be in the way of the air bag</TD></TR></TABLE>
I would HIGHLY recommend disconnecting the airbag if you run a race seat. The seat/bag are designed to work together and chances are very good the new seat position will not be good. Unfortunatly there is no way to know until it's too late.
I don't know about the rib collapsing thing... If everything is set up right, it's all real safety equipment. If it kills you, why is it a mandated change for damn near every class of racing? Do racecar drivers have super-ribs or something?
Old Nov 22, 2006 | 05:58 PM
Ok. I may or may not get seats soon. If I decide NOT to get seats at all, is there a way to add lateral bolster so I don't go swaying when I take turns hard?
That's primarily my concern...I haven't had too much a problem with back support (found my Sparco Speed MORE supportive vs. OEM VW seat)
And to standback...I would have racing harness for canyon runs or spirited driving sessions..NOT for daily use. Seats in question are of the reclinable sort like Sparco Torinos or Corbeaus
Old Nov 23, 2006 | 12:23 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prodigal Son &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know about the rib collapsing thing... If everything is set up right, it's all real safety equipment. If it kills you, why is it a mandated change for damn near every class of racing? Do racecar drivers have super-ribs or something? </TD></TR></TABLE>
no they do not but they do wear hans device, helmet and their cam lock harness is actually mounted on a harness bar or rollcage/loop in a proper angle unlike a streetable car. you could "set it up right" but it will not be very streetable(you might argue but no, a 6 pt rollcage w/ harness and helmet is not imho.
Old Nov 23, 2006 | 07:18 AM
BlUAc's Avatar
Default Re: Want to install aftermarket seats but retain OEM seat belt buckle... (iam7head)
i have a set of spearcos in my 4th gen and I have the stock seatbelts in I was going to put in some 4 pionts but for the same reason I didnt I used my stock bracket and cut the sopts where it comes up and weld some 3/16 in strips of steel accross and welded it good then my stock belt can stay in its same spot
Fnix
Jan 19, 2013 11:24 AM
The Alchemist...
Aug 5, 2005 10:05 AM
ff terror
Nov 7, 2004 12:24 PM
imlachg1
Mar 22, 2003 11:03 AM
FDragger
Oct 9, 2002 07:22 AM
