Suspension & Brakes Theory, alignment, spring rates....
What do I need to put sleeves on my Koni Yellows?
Old Nov 18, 2006 | 05:55 PM
future62
Guest
Posts: n/a
Default What do I need to put sleeves on my Koni Yellows?
I want to put the Omnipower sleeves on my Koni Yellows. What do I need to get to do this? I know they won't sit on the perches as is.
Old Nov 18, 2006 | 08:53 PM
slammed_93_hatch's Avatar
Default Re: What do I need to put sleeves on my Koni Yellows? (future62)
AFAIK you can't. You need special sleeves to run on the koni's.
Ground control is the only one who makes a setup that works on the koni's.
(and koni does too buts it end up being much more expensive then the GC's)
Old Nov 19, 2006 | 05:05 AM
future62
Guest
Posts: n/a
Default Re: What do I need to put sleeves on my Koni Yellows? (slammed_93_hatch)
Hmmm, that sucks. I might be selling my setup then for Illuminas+Omni sleeves...
Old Nov 19, 2006 | 07:38 AM
Tyson's Avatar
id get rid of your omnijunk sleeves.
Old Nov 19, 2006 | 07:52 AM
Pondus's Avatar
If you have the Yellows already, definately get a set of Ground Control sleeves instead of a Illumina/Omni setup.
Jake Fowler
Suspension & Brakes
Jul 14, 2012 06:45 AM
unc25
Suspension & Brakes
May 19, 2012 12:15 PM
RHGSR01
Feb 2, 2010 11:01 AM
Isaac
Mar 25, 2002 10:58 AM
