clutch, master cylinder, slave cylinder? what is it?
Old Nov 18, 2006 | 05:33 PM
210rudelude's Avatar
Default clutch, master cylinder, slave cylinder? what is it?
i recently purchased a 94 prelude.
i burned out the clutch and replaced the master and slave cylinder, along with
the pressure plate, and fly wheel.
the problem i have is that when i pick up into 2nd gear it starts to
over rev. 5k rpm going 25 and not picking up.
what should i do..?
also i cant get it into 2nd gear with out grinding. the mechanic
said it has to do with something in the transmission.
i have to get the rpms down to 1k before i can get a good shift
with out a grind.
what do i do??
i was thinking of getting rid her but it would be a shame not to
try to fix her....
any info or tips would greatly be appriciated.
pics on http://www.myspace.com/prysm
Old Nov 18, 2006 | 05:43 PM
Hawkze_2.3's Avatar
Default Re: clutch, master cylinder, slave cylinder? what is it? (210rudelude)
Sounds like you had the wrong parts or didn't install them properly.
Old Nov 18, 2006 | 09:19 PM
Duane_in_Japan's Avatar
You will need to see if your relaease fork has free play, your clutch is slipping, maybe wrong clutch kit or fork problem.
Old Nov 19, 2006 | 04:18 PM
Default Re: clutch, master cylinder, slave cylinder? what is it? (Duane_in_Japan)
release fork..
good idea man thanks for
the tips..
Civicfanatic_09
Jan 20, 2010 08:58 PM
johnqt3
Oct 7, 2005 11:05 AM
djtsmith007
Mar 21, 2005 07:02 PM
tim.simpson
Oct 18, 2002 06:23 PM
