how do i remove the backseats from a 4th gen?
the bottoms should pop out by some prongs underneath the front, once you get those out there should be a bolts to get the backs out its been a while since i removed mine you shold be able to figure it out from there.
You remove the seat bottoms first. There are two clips on each side of the front of the bottom foam part of the seat, simply pull out on the plastic "T" clip. It may help to push down on the seat cushion while you pull the clips. The bottom part will now slide out toward the front of the car. Now you will see the bolts holding in the back part of the seat.
