Calling GReddy Header owner...
I need some true and honest opinion. How would you rate your GReddy header on your Si-VTEC?
Please don't tell me go DC. Mugen would be nice, but they discontinued it for the 4th gen. I heard. Spoon is also discontinuing their as well. So I have not much choice. Please help.
i if you want some hardcore **** get a sms adjustible header and exhaust.
He, he, he, Im pretty hardcore... If you want a badass header, and don't mind cutting the subframe for a 4-1 with 2.5" collector, SMSP is the way to.. 179hp on stock motor...
P.S. is there any word on the legality of the SMSP header?
we want to do some testing with a 4-2-1 before he markets it.. hopefully it will fit with less cutting, and more ground clearance, and retain the same amount of hp his 4-1 made..
i dont mind cutting subframe.
when do you think they will be available?
yes..when will it be available? and is there a website to order it at? also...about cutting the subframe....since I swapped an h22 into an integra....I don't have to worry about this correct??
Is there any word on the legality of the SMSP header?
Pertaining to CARB approval, I don't plan to go through that process for any of my race headers. If someone decides to use it on the street then I have no control over that. Also if a header gets CARB approval (a very long process) and then development changes the design for the better the previous approval is void.
Lets say I did use a 2.5" cat, do you think it will pass emissions if I put some dry gas in the tank, I heard it helps?
[Modified by piotrush, 7:09 PM 5/26/2002]
sushibug
Jun 30, 2004 06:59 PM
