SRS steering column problem
Old Nov 18, 2006 | 04:26 PM
honda genome
Guest
Posts: n/a
Default SRS steering column problem
Ok, so my horn, audio switches, cruise control switch, basically all the switches around the steering wheel stopped working. I opened it up and it was the electrical coil thing that you call the SRS column where it allows you to turn your steering wheel while being able to control the electric things like the horn etc....I turned it a few times and it started working fine, until I made a complete uturn and it stopped working...not sure if anyone has had this problem before, please chime in
Old Nov 19, 2006 | 09:23 AM
hondadude's Avatar
Default Re: SRS steering column problem (Honda Genome)
Replace it; be sure to have it aligned correctly when you re-install the steeing wheel. it only turns so far in either direction. The new one will come with a piece of tape holding it in the center position.
NEO_FOLLOWER2
Jun 13, 2011 03:56 AM
jdm_j03
Honda Civic (2001 - 2005)
Feb 25, 2008 09:18 PM
Hayasa15
Sep 3, 2002 06:46 PM
