hondata reflash?
i was wondering is it ok to run a hondata reflash for a k20a2 with i/h/e? i heard that u couldn't run the reflash because it would lean out in the higher rpms, but isnt the reflash better than the stock ecu? and the stock ecu doesnt lean out rite? well n e help is appreciated thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madru17 »</TD></TR><TR><TD CLASS="quote">just will run too lean with the race header</TD></TR></TABLE>
yea you will run too lean with a race header. I would recommend saving up and getting kpro. it will be one of the best investments for your car.
i believe the mod is made for just a CAI. with a race header you would run a bit lean.. not dangerously but it really depends on the individual car as well. Some run fine and some are a bit lean. To be on the safe side go KPRO.
but it says that the k20a2 runs rich stock and by adding the header and reflash makes it run a little lean but it runs ok, is that not true?
