Best Clutch
Old Nov 18, 2006 | 11:48 AM
WalkerGSR1's Avatar
Default Best Clutch
What is the best lutch and flywheel to use on a daily driven turbo GSR making 300-350whp? Everyone give me your opinion i have a xtd stage 3 but my frined said that wont hold the power. So i am looking for more choices and opinons on this.
Old Nov 18, 2006 | 11:55 AM
92TypeR's Avatar
FSAE
Default Re: Best Clutch (WalkerGSR1)
best clutch? Exedy Hyper Carbon.
Will last longer than the car (~200k miles), and can hold 800hp.
MSRP $2,100
But if you want the most cost effective clutch, Exedy Stage 3 should work fine. Same goes for Clutchmasters Stg3 and ACT HD blah blah...
Old Nov 18, 2006 | 03:21 PM
WalkerGSR1's Avatar
Is that clutch good for daily driving? and my limit is about $500-$600
Old Nov 18, 2006 | 04:01 PM
95 integra's Avatar
Default Re: (WalkerGSR1)
I'd rock out with the ACT XTSS. Might be a little overkill for 300-350whp but you'll have no problems with it and by going slightly too aggressive it will make the clutch last a little longer then going with a weaker clutch.
Old Nov 18, 2006 | 06:54 PM
WalkerGSR1's Avatar
anybody else i need a clutch that holds around 350whp
Old Nov 18, 2006 | 07:30 PM
WalkerGSR1's Avatar
Anybody know how the exedy stage 2 3 puck clutch cerametillac drives? does it have smooth engagement? how much does it handle
Old Nov 18, 2006 | 10:24 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">Anybody know how the exedy stage 2 3 puck clutch cerametillac drives? does it have smooth engagement? how much does it handle</TD></TR></TABLE>
not sure about how much power it can handle, but that's what i have on my gsr that i'm turboing. i'm only going for 250 whp so i'm sure it'll be enough for me. the engagement is pretty rough if you don't hit the gas very hard when starting off; you have to gas more than usual on startoffs and let the clutch out quick. otherwise it chatters pretty bad.
Old Nov 19, 2006 | 01:52 PM
WalkerGSR1's Avatar
bump
Old Nov 21, 2006 | 01:29 PM
dthug's Avatar
yo just get the exedy stage 3. those clutches are real nice and can hold that kinda power
Old Nov 21, 2006 | 05:41 PM
gsr dood's Avatar
Default Re: (dthug)
xtd stage 3 4k miles no slippin yet
Old Nov 21, 2006 | 06:14 PM
WalkerGSR1's Avatar
Default Re: (gsr dood)
Is your car boosted? if so how much power does it make?
Old Nov 22, 2006 | 06:49 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">xtd stage 3 4k miles no slippin yet </TD></TR></TABLE>
let's hope not. if you're clutch is slipping within 4k miles then you have major issues.
Old Nov 22, 2006 | 08:11 AM
Swiftstar's Avatar
Default Re: (civicdxtyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">
let's hope not. if you're clutch is slipping within 4k miles then you have major issues.</TD></TR></TABLE>
lol. my thought exactly. if any clutch for that matter is slipping with only 4k's on it, then.lol. i dunno about that 1.lol
Old Nov 22, 2006 | 08:24 AM
juda7's Avatar
I DD a ClutchNet 4 Puck Unsprung. But that's just me cuz I'm not right
ClutchNet also has 6 Puck sprung clutches that will grab 350+
That's my 2 pennies
Old Nov 22, 2006 | 08:44 AM
95 integra's Avatar
Default Re: Best Clutch (juda7)
Clutchnet . Slipped from one end of interstate to the other. Given that was on an organic disc w/ red pressure plate.....but I never had a problem with the ACT XTSS.
Old Nov 22, 2006 | 08:47 AM
neovvl's Avatar
Default Re: Best Clutch (95 integra)
Modified by neovvl at 10:30 AM 11/22/2006
Old Nov 22, 2006 | 08:51 AM
juda7's Avatar
Your ClutchNet might have slipped due to the amount of HP you were pushing.
I had an Exedy Organic and it slipped in every gear. Again, too much HP.
Buy the right clutch for the right application.
Old Nov 22, 2006 | 09:18 AM
95 integra's Avatar
Clutchnet red pressureplate w/ organic disc should be equal to the XTSS....I know the clutchnet slipped due to the hp, but the same type setup w/ ACT did not. Sorry if I dont want to go with a pucked clutch or a unsprung clutch.....I dont have to because ACT sells a sprung organic disc that will hold 350whp.
Old Nov 22, 2006 | 09:23 AM
DC2_ALL MOTA's Avatar
I had an xtd stage 2 for my gsr and its the worst clutch out there. Only had it in for 2k miles and took back out cuz it was slipping, and looked as smooth as a brake rotor.
Old Nov 22, 2006 | 10:35 AM
juda7's Avatar
This clutch was free due to a dyno bet that I won. (Organic Exedy held the HP )
Anywho, hey whatever you or anyone feels comfortable driving around with.
I use this one cuz the price(free in this case) and the way it grabs.
Old Nov 22, 2006 | 01:02 PM
crispchris's Avatar
i'm not sure if i can give real good insite in comparison between different clutches
because i've only driven a clutchmaster stg 3 clutch with exedy flywheel and a
stock setup that had 80000+ miles on it but the clutchmasters feels perfect to me,
very good daily drivability imo .
Old Nov 22, 2006 | 02:40 PM
juda7's Avatar
Default Re: Best Clutch (crispchris)
X2 Exedy flywheel
eghatchfla
Aug 8, 2010 07:06 AM
95_red_dc
Transmission & Drivetrain
13
Nov 10, 2008 03:16 PM
pjr710
Jul 23, 2008 09:53 AM
TEGGRY
Jan 27, 2006 05:50 PM
Nextelbuddy
18
Jul 8, 2003 07:46 AM
